Question about Poulan Garden
PO500N225 Poulan rotary mower, purchased new in July--trouble starting it. Ran a few seconds, then stopped. Now will not start at all. Also, where can I get a user manual for this fine piece of equipment. None came with the purchase, and all I find are parts lists on the internet. Ha! Please help
SOURCE: Durabrand Model W600-S User manual
This one does not have a clock function. It doesn't show anything in the manual about setting the clock and ours never had the time on it.
Posted on Jun 24, 2008
#1 Taper
  • 1041 Answers
SOURCE: mower starts fine, however have to keep priming
You will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spraywith carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or jet in carb. These portals can become blocked. you may need to replace the diaphragm. Reassemble and start.
(NOTE:If the carburetor parts are more than four years old, and depending onthe use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Posted on Jun 19, 2009
  • 53 Answers
SOURCE: The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Posted on Aug 12, 2009
wilsodfarm
  • 986 Answers
SOURCE: Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Posted on Sep 10, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Posted on Sep 14, 2009
New Poulan Pro blower/vac won't start
I would back the carb screw out 1/4 of a turn. And yes 15 pulls should start it.
Nov 12, 2013 | Poulan 25CC Gas BlowerVac
TRY MY SELF PROCLAIMED TRICK: THE ON THE MOWER CARB REBUILD.
1. GAIN ACCESS TO CARB THROAT
2.FILL ENTIRE FLOAT BOWL WITH SPRAY CARG CLEANER
3.LET SIT
4. DO THIS A FEW TIMES....MAKE SURE PLUGS ARE "NEW"...OR ABSOLOLUTELY CLEAN...DRIP A FEW DROPS OFF GAS INTO SPARK PLUG HOLE...RETHREAD PLUG...FIRE IT UP UNTIL IT RUNS AND PULL THRU AND BLOWS OUT ALL IN CARB
Jul 21, 2013 | Poulan "Poulan" Push Mower
I just bought a Poulan PR550N21RH3 Rotary Lawn Mower. The first time I used it it worked fine. While I was mowing the second time I heard a big "POP" then it began to shimmy. What should I do?
check the blade to make sure its on securely and isnt bent or broken.
If something went wrong other than blade damage I would take it back and ask for a replacement.
Jul 30, 2010 | Poulan "Poulan" Push Mower
Primer will not pull gas to carb and will not run. gasket replaced
You can check the priming circuit manually by pulling the plug off the spark plug and then with our hand over the air inlet to the carb have someone give the mower 3-5 pull starts. Then, put the plug boot back on and try to start it. Did it work? Is it still running? If it started and ran your primer bulb probably has a leak and needs replacement. If it started and ran for a few seconds and died clean out the main jet and the bowl inlet.
You can look at the breakdown of the carb in your manual to see where these parts are. Or just go online and find a familiar carb diagram and work from there.
Good luck and be careful!
May 24, 2010 | Poulan "Poulan" Push Mower
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
It won't keep going.
Remove and clean out the carburettor, its dirty and full of old dead fuel.
Apr 25, 2010 | Poulan "Poulan" Push Mower
Cranks over but will not start....when it did start (once) it ran for a minute or two and stopped. The mower is 1 year old. What to do?
There are a few things you should check.
1. Make sure the undeside of the deck is allow free rotation of the blade.
2. Make sure the blade is secure firmly to the shaft.
3. Adjust choke (lever at front of engine).
4.Does throttle cable pull carb linkage adequately?
Apr 11, 2010 | Poulan Pro " Pro" Self Propelled Mower
Sep 10, 2009 | Poulan "" Push Mower
Garden Logo
131 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
