Question about Boating
I previously had my 1930 radar connected to a Raynav 570 loran. The "ship's own" position displayed correctly at the bottom of the screen. This connection used only the yellow and green wire. The black and white were not connected. I have replaced the Raynav with a Garmin 178c. I have successfully connected to the Icom m602 radio, the position displays on the screen. However, I am unclear how to connect to the Furuno 1930. Do I need all 4 wires? or just 2 like before? Is the Furuno capable of recieving NMEA from the Garmin ? Please advise correct connections.
  • wellcraft37 Sep 01, 2010
    I have no Furuno blue wire. only black,white yello,green. Do I need all 4? the Loran only used the yellow and green? I know how to configure the Garmin, How do I set the Furuno? RLH.
  • 944 Answers
All the information needed (color codes for wires) for the Garmin end will be good.On the Furuno end the manual is not good.just shoot an E-Mail to Furuno they would mail they are friendly customer care.For some models the connection may differ.So it is better you mail them and get a copy.
Pin 1 TXD-H White
Pin 2 TXD-C Black
Pin 3 RXD-H Yellow
Pin 4 RXD-C Green
Only two wires from each device required.
So following this scheme, NMEA OUT would be White(+) and Black(-), NMEA input Yellow receive(+) and Green(-)
you should hook the Furuno's NMEA transmit to Garmin's NMEA receive.
You have to contact Furuno for the colour coding of the Furuno cable.
NMEA out from the GPS and NMEA in to the other device. The Garmin then has a I/O screen for setting the NMEA output and the Furuno requires configuration settings as well.
Furuno************* Garmin
TX+*(white)****** RX+
TX-**(black)****** your boat's DC ground (same ground used by the Garmin)
Furuno White to Garmin Brown
Furuno Blue to Nothing
Furuno Yellow to Garmin Blue
Furuno Green to Ground
Furuno:
1-White wire (transmit data+ or/receive+)
2-Blue wire (transmit data- or/receive-)
3-Yellow wire (receive data+)
4-Green wire (receive data-)
5-Red wire (+12VDC out)
6-Black wire (-12VDC out)
7-Bare wire (Grounding wire)
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 01, 2010
    sorry its funro black in your case...
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
Good day, I just bought a transducer (R209) for my 1920 C furuno display but seem to have a probleem with the setup on the display. I have no radar connected to the system and to do the installation...
If you just have the transducer and no network sounder youre pretty much dead in the water. along with your transducer, you will need either a BBFF1 or DFF1 sounder. Since they operate on a network they will have to be configured depending on your setup.
Oct 07, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Will this radar detector detect a ship's radar?
Yes. Most ships use a combination of X band radar (which practically all radar detectors will pick up), and S band radar. The Navy is currently looking to redesign their radar systems, but budget constraints and additional space on board the ship are two major hurdles they have to contend with. You can find this answer rather easily on the internet by searching for "ship radar bands". Hope this helps.
tasparx@hotmail.com
Aug 16, 2010 | Vehicle Parts & Accessories
Im using a 3728 radar open array..the scanning seems to be find but there's a solid circle right at the center that is blocking the display so i can't anything near my ship..
You will need to adjust the timing on the radar antenna which is in the setup menu. You will need to refer to the installation instructions on exactly how to access the installation menu. There should be a small circle in the center of the screen, but not like you are mentioning.
Mar 01, 2010 | JRC Jma-2343 4kw Crt Radar
My ship furuno radar hasn no sweep only a center dot.all other fed in information like speed,GPS input o.k.
The symptom you describe sounds like a case of no radar targets. To further diagnose, put radar on the longest range and turn Gain to full, Sea Clutter to Minimum, Rain Clutter to Minimum, and observe the screen. The presence of "grass" or evenly distributed clutter indicates that the receiver and cabling is good and the radar may not be transmitting. No transmit is caused by a bad magnetron or a bad modulator in the antenna, or depending on model there is still an outside chance that the power supply in the display has failed.
Dec 29, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno 1942Mk2 Problem
it cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Nov 14, 2009 | Furuno 1942 Mk2 Radar
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Converting loran numbers to GPS. Loran TD coversion won't let me put in my loran numbers. My loran numbers have more digits than it will allow me to put in.
When you enter the Loran coordinates, they should only be 6 digits with one decial point ie: 12345.6
On the chart the coordinates may be shown with a prefix such as as 9960-W14123.4. The prefix (9960-W) is not entered on the conversion screen. It has to be set up in the position format set up page in your GPS prior to doing the conversion.
For example on my Garmin 76CS, I go into the setup menu and select position format.
I scroll down through the list of formats until I find "LORAN TD" and press "enter".
In this screen I enter the master chain number, which is 9960 for my region in New England.
I also have to enter the "slave" stations which are designated as V,W,X,Y, or Z. For example, in my region, the "W" slave station always starts with the number 14 (ie:14123.4) and the "Y" slave station always starts with 44 (ie: 44123.4).
When I am in the conversion screen, I don't have to enter 9960-W because the GPS is already formatted for that.
You should also note that a LORAN TD converted to Lat/Lon will not be as accurate because there is some mathmatical error in the conversion equation.
Jul 20, 2008 | Garmin GPS
Boating Logo
214 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
