Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Cleaner just spins - Hayward Phantom Pool Cleaner Complete with Booster Pump
  • 640 Answers
If the cleaner is spinning in circles, it a probably a problem with the hoses of these pool cleaners. It was was a common problem with early models, and they have just redesigned it. Lay the hose out in the sun, stretched out, and let it sit for several hours to straighten out the hose. Make sure that you are not storing the hose in a coiled position since they are prone to bend and break.
Posted on May 25, 2011
Why Dyson dc39 brush bar won't spin
Remove brush bar cover...is the belt broken, cut or stretched to the point of being ineffective? Is the brush bar full of hair or string?
Pull the belt forward...does the pulley spin? Turn the cleaner on
and see if the pulley spins...if it does I think a new belt will be needed.
Be sure to buy the right one.
Regards,
Dennis
Aug 18, 2014 | Dyson DC39 Animal canister vacuum cleaner
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
How to repair roller on Vacuum cleaner
it migh be the belt.stretched and hardened from heat replace and try again
Feb 02, 2012 | Electrolux Vacuums
Cleaner will not stop spinning
It could be a bend or kink in the pool cleaners hose. If you store the hose coiled, this is what is causing it. Try laying the hose out in the sun and let the hose straighten to its original form. It could also be heavy debris in the cleaner or the pressure being too high. You might need to adjust your spin out options.
Sep 24, 2010 | Hayward Phantom Pool Cleaner Complete with...
Phantom does not move gets stuck in one spot
Is the cleaner getting stuck at steps, corners, etc? If so, your spin out is too short. Change the cam to the "winter" position to increase the pool cleaners spin out.
Aug 22, 2010 | Hayward Phantom Pool Cleaner Complete with...
I am pulling the trigger and the carpet solution won't spray out
too much cleaner in the mixture, do you see the little fan type thing in the window spin usually when you dispense cleaner well it won't spin and dispense cleaner if you get it too soapy or concentrated.
Jul 07, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
267 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
