Question about General Electric 30 in. Profile PP975 Cooktop
I have a GE Profile electric cook top that shut off while I was using it and now it won't turn back on. Does anyone know what the problem could be? I checked the circuit breaker and it is fine.
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
  • 161 Answers
SOURCE: glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Posted on Jul 15, 2008
  • 1214 Answers
SOURCE: GE profile performance electric cook
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Posted on Jan 23, 2009
heatman101
  • 43501 Answers
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
SOURCE: G.E Profile gas cook top #JGP640 ignitor.
I just moved into a house, have a G.E Profile gas cook top #JGP640, the problem is when I turn of the front right burner, the electronic ignitor doesn't turn off and make the other three sparking the same time and won't stop, driving me nut. I double check all ignitors are cleaned. What else should I check or should I just give up????
Posted on Oct 06, 2010
How far away do I need to sit my GE induction cook top back from the front of the cabinet?
Try to centre it so you have an equal distance both front and back that way il has clearance and also looks better than being out of kilter.
Ray
Apr 22, 2014 | General Electric PHP900DMBB GE Profile 30"...
GE Profile cooktop JP360. Trying to remove cooktop to install new granite countertops. Also have GE built in oven JTP 15 below. Called G.E. Customer Service today and was told to just pry the top off...
Hi marilynmcdon,
You can do it yourself. These cook tops are not glued to the granite at all (Or is not supposed to be). Simply lift is up slowly, start from the side, and lift it slowly. If done carefully you won't damage anything.
Hope this helps
JEDEMEYER1
* If this solution helped you, please rate it.
Aug 09, 2011 | GE 30 in. Profile JP350 Electric Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
How to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
Nov 15, 2010 | GE Profile JP930 Electric Cooktop
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
General Electric 30 in. Profile PP975 Cooktop Logo
61 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
