Question about Whirlpool GGW9250PL Gas Dryer
The machine runs but wont heat up - Whirlpool GGW9250PL Gas Dryer
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 01, 2010
For the Taylor C709-27 soft serve machine - what does it mean when someone says it wont go in the heat cycle overnight?
The Taylor C709 is a Heat Treat machine. Most soft serve machines have to be cleaned out every 3rd night and sanitized. Heat Treatment machines heat the mix up to a high temperature that kills bacteria and allows you to disassemble and sanitize the machine much less often. I can't tell you why, but the machine you are dealing with isn't running that heat cycle.
May 10, 2017 | Taylor Ice Cream Makers
I just got this machine new and feed dog
It may just be stuck from being in storage and unused.
Try oiling the machine as per the manual, lowering the feed, and running the machine. The movement of the linkages may free things up. Another thing you can try is applying heat from the underside (open the bobbin access door and blow the heat in) as the heat will allow the oil to seep in better...then run the machine some more.
May 14, 2010 | Juki TL-98Q
Dryer runs...timer wont rotate and wont heat up
Good day,
Timer woun't run if there is n heat.
1. Check to see you are getting 230 volts to the machine. The motor uses only 115 so is not a good indication.
2. Remove back cover. You will need an ohm meter to test the components.
A. In the center bottom is a skinny white bakelite device held on with one screw. Remove one wire and check. It should check zero ohms. If not replace.
B. On the bottom right is a canister with the heating element terminals sticking out. They should test at 30 or less ohms. If not replace the heating element.
C. There are about 3 other limit thermostats in the area you're working. They should all check at zero ohms. Replace as needed.
Below is a tutorial on changing a heating element.
http://www.applianceaid.com/wp_element.html
Mar 02, 2010 | Whirlpool Dryers
Kenmore elite dryer wont heat
heater element needs repair but usually replacement
Jul 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water wont heat up
If your DW has an "energy saver" or "no-heat" button for wash or rinse, make sure it is not selected.  If that is not the case then the heating element is probably burned out and needs to be replaced.
Jun 02, 2009 | Beko 24 in. D3421F Free-standing...
Dryer wont turn on, I reset main breaker but the dryer still will not turn on and run
overheat thermostate is located inside the machine, there may be a serious fault with or short with the heating element,. Good Luck - the Yeti
May 17, 2009 | Dryers
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Machine wont draw any milk through
You are not supposed to put milk in the resevoir and run it through the machine. That's likely the problem. But like most parents you will continue to blame your child until he is totally alienated and your relationshio is an empty shell.
Dec 13, 2008 | Breville ESP8XL Espresso Machine
Dryer wont spin
Doe the motor running ? if run w/out spinning the beltis the problem / bring sample to appliances center.
Aug 25, 2007 | Kenmore 45081 Front Load Washer / Dryer
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
