PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Got following error: Load Error! Press any...
By maritsa on May 09, 2008
Dear Expert,
Please note that I just finished downloading the Recovery and Applications/Driver DVD Satellite M50/M55 utilizing the corresponding CD. When the CD is finished I get the following message: "Load Error! Press any key to reboot...." but when pressing any key and the same message appears "Load Error! Press any key to reboot...". Please help!
Thank you for your prompt answer.
Laura
Same Problem
Mar 10, 2009
-   I have a problem, my PC always say LOAD ERROR. What is the solution? -   Guest
Sep 10, 2008
-   I,m experiencing the same problem. my toshiba m55 showed Load Error. I used recovery disc and nothing changed, the load errar still there.
any solution, please help.-   mariolat
Aug 08, 2008
-   "Load Error!"
"Press any key to reboot..."
lap top will not startup
-   Guest
Solution #1
posted on May 09, 2008
Somewhat Helpful)
Roshan89
Rank: Wiz
Rating: 81%, 204 votes
The disk can be damaged (read errors)...if it is impossible to read it automatically asks you to reboot
Was this helpful?
Yes
No
Solution #2
posted on Nov 19, 2008
Very Helpful)
techneck09
Rank: Apprentice
Rating: 100%, 1 votes
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 18, 2009
Not Rated)
TechCity
Rank: Apprentice
Rating: 0%, 0 votes
The circumstances I was confronted with when a customer brought his Toshiba Satellite M35X-S1492: He received the Load Error! Press a key to reboot error. He was smart and had a backup of all his important files. He also had his Toshiba Recovery CD. So he did a destructive recovery (erased the drive and did a clean install. When finished, he still received the same error. I replicated his efforts and also received the error message.So I had a look at the Recovery CD and discovered that it appeared defective as if moisture had seeped into a third of it. So I used a Dell XP Home OS Reinstall CD to boot the machine. I deleted the only existing partition and did a clean install of XP. End of error message. Activated Windows without incident over the internet an downloaded the latest drivers from Toshiba. No problems since then. BTW, thanks for the tip from techneck09.
Was this helpful?
Yes
No
Solution #4
posted on Oct 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I am a A+ Certified Computer Tech for a bigbox store and this error is caused by a corrupted MBR. The only solution we have found is to zero the disk, format it, partition it, and then run the Toshiba recovery discs.
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how do i restore my aspire 5735-6694
Answer
not able to recognize the SAMSUNG HM100JC on my Lenovo Thinkpad
Answer
Acer Extensa 4220 with Celeroun 2.13 Processor Laptop problem for Bluetooth Driver and Operating... (More)
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
