Question about Dell Office Equipment & Supplies
I ran out of color ink and needed to print right away. I couldn't find any color ink anywhere. I took my empty and got it refilled with Dell ink. The printer still said I was out of color ink. I sent off to Dell and my new cartrige arrived today. The printer says I have plenty of both inks but it will not align or print. It is doing what it did when it said I needed ink.Model AIO944
  • sadsam392 Sep 06, 2010
    I did everything you told me to do. It still will not work. The computer keeps saying it cannot start the program. Am I to take that to mean there is something wrong with the printer? sadsam392
  • 472 Answers
  • The best way is to uninstall your printer drivers completely from add or remove programs.
  • Disconnect printer from computer
  • Restart the computer
  • Install the drivers and connect the printer when it asks for it
  • after drivers are installed you will be able to print the documents
Good Luck!
Posted on Sep 01, 2010
  • Pulkit Tigrania
    Pulkit Tigrania Sep 06, 2010
    If it is still doing the same than it means there is a problem with the print head. You can get it checked once locally.
Can Dell A960 ink cartridges be refilled and re-used or not?
A lot of inkjet printer manufacturers make you purchase their ink cartridges by installing a chip in the cartridges so when the cartridge is empty it cannot be reused by filling the cartridge.
Jan 28, 2013 | Dell A960 All-In-One InkJet Printer
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
Color ink cartridge
Hello sir; Please do not use refill cartridge ! , one cartridge not right all cartridge don't work. change back the refill one.
Aug 02, 2009 | Dell 924 All-in-One InkJet Printer
Ink and printer
You'll need to either put it back in or replace it.
You need to have both color and black cartridges in for your printer to work.
Never throw away cartridges, save money and refill them or you can take them to most any computer store for recycling.
Mark
Apr 14, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Mar 24, 2009 | Dell 948 All-In-One InkJet Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Aug 09, 2008 | Dell 922 All-In-One InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Losing Ink
Depending on how many times you have refilled the wells of the cartride the sensor inside may be going bad as the manufature of the cartridge only intended it for a one time use. My recommendation would be to buy a off brand compatible and refill those.
Mar 07, 2008 | Canon BJC 8200 Photo InkJet Printer
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
