Question about NetGear WGT624 Wireless Router
Triying to hook up a wireles printer get stock when they ask for the code or ip addres of the router help me please
  • 550 Answers
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Click Here for step by step instructions
Posted on Sep 01, 2010
I don't find the IP addres on my modem, my modem is a 2wire 2700HG-B can you help me find it? or do you now it?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access it with above ip then press RESET button for 10 seconds then all settings defaults. Then you can access it with above default ip. Let me know if you need further assistance. Thanks for using FixYa.
Oct 07, 2010 | 2wire 2700HG-B Router (2700HGB)
Tip
Getting 169.xxx.xxx IP address of the printer on wireles network
IP address 169.xxx.xxx is invalid IP over the network<br /><br />Go to printer front panel<br />restore network defaults<br /><br />restart printer<br />go back to front panel<br />look for printer wireless network settings<br />print configuration or network page to check if printer will have 000.000.000 IP address which should be<br />if it is then run the wireless set up wizard to connect the printer again over the network and get new IP address<br /><br />If doing above doesnt fix the issue<br /><br />Go to printer front panel<br /> restore network defaults<br /> <br /> restart printer<br /> go back to front panel<br /> look for printer wireless network settings<br /> print configuration or network page to check if printer will have 000.000.000 IP address which should be<br />turn off the router<br />turn off the PC<br />turn off the printer<br /><br /><br />then do sequencial rebooting<br /><br />How?<br /><br />1. Turn on the router<br />2. Turn on the printer<br />3. Turn on the pc<br /><br />check the wireless settings of the printer and new IP address should be given this time it should be valid one<br /><br /><br />Why?<br />by turning on the printer first router will give the very first IP address to the printer before PC huge chances for the printer to get valid IP will be possible<br /><br /><br />If still unresolved<br />contact network provider to check for security settings of router such as<br />Firewall<br />Mac Filtering<br /><br />Hope I help you a bit.<br /><br /><br /><br />Your's Truly,<br /><br />Christian from HP<br />
on Mar 27, 2011 | Office Equipment & Supplies
How to know the MAC address of my infoprint . In the config menu I got one but contains only 5 groups
If the printer is configured and has got a TCP/IP address, you can get the MAC mapping from any Windows PC in the same network like this:
Start -> Run Command -> enter "CMD" and press Enter -> type the command, PING ip.addr.of.printer (enter) and then ARP -a ip.addr.of.printer (enter).
If your network's IP addresses are centrally managed, ask your system administrator if it's possible to temporarily assign a fixed IP address for diagnostic purposes, then assign that address to the printer and do as described above.
Oct 30, 2009 | IBM Infoprint 1622 Laser Printer
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
Router Problem
Go to start / run tye in the run box (cmd or (command) then in the plack screen type in ( ipconfig /all ) look for the defalt gateway that will be the ip adress you need to type in to get to the router login unless you have a complex network
Sep 21, 2009 | Black Box IP Address Translator With...
How can i use as a second router to expand my
connect every wireles router to a modem with more output posibilitys ore conect to output from first wireles modem so you can chooce witch wireles modem wil connect to the laptop or pc
Aug 22, 2009 | Zyxel Prestige 600WH Wireless Router...
Cannot get on xbox live
The IP addres it is asking for is from your wireless router. (You do have one hooked up, rigth?) You can get this by going to any of your PCs at home and opening a DOS command prompt. Usually you can get there by clicking Start and clicking on Run. A little box opens. Type in cmd and hit Enter. Up comes the black window with white text. You will type in ipconfig /all. There is a space between the g and /all. Up pops the IP configuration for your home system. If my old man's memory serves correctly, it will need the Default Gateway address typed in from which it will get its own IP address. I admit it has been about 3 months since I hooked up my last one but I believe that to be the correct method. After that, it will send out a test signal to make sure you can access the Live features. Let me know if this helps you.
Feb 16, 2009 | NetGear DG834G Router
Changing IP address on computer with router linksy802.11b
access your router with ip.
open internet explorer if your defualt router ip is :192.168.0.1 type this http://192.168.0.1 in addres bar in IE. then neter username admin and password aslo admin
if not accepr blnk user name and passowrd is admin.
then go to ssytem then set ip and follow the procedure.
Oct 06, 2008 | Linksys BEFW11S4 802.11b Wireless...
Dynext router
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 09, 2008 | Dynex Computers & Internet
I have a wireles belkin router and the power light is on and the wireles light and the phone light and the internet light but i still cant get on to the internet with either my wireles laptop or though a...
go ahead and power everything down. wait a minute then plug in your router. once all the lights are steady power up your pc. once complete go to run, type cmd and enter. At the prompt type ipconfig and enter. ping your ip address.
Jun 01, 2008 | Belkin Computers & Internet
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
20 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
