My computer has a black backgroung that is hard to read. This happened before and I was able to fix the problem. Do you have any suggestions ?
  • 808 Answers
Chek ur vga cable or vga and use rginout to fix ur problem
Posted on Sep 01, 2010
Hardware scan shows failed surface scan test,targeted read test & smart short self test timed out,how to fix these problems
These are problems that cannot be fixed, basically your hard drive is on the way out. Typically this is caused by drops, bumps, etc. while the machine is on.It has a SATA 2.5" 120gb 5400 RPM drive, I would suggest a larger 7200 rpm drive but it is up to you. You will also have to reinstall windows to the new hard drive.
May 17, 2011 | Dell Inspiron 1525 Laptop Jet Black
My PC is not able to read my Acomdata portable hard drive. Any suggestions how I can repair on my own? Thank you.
Try hooking up the hard drive to another computer, what happens? Which version of Windows are you using? Was the external drive ever connected to a MAC?
Mar 18, 2011 | Acomdata (HD160UPE5-72) (HD160UPE572) 160...
Dell inspiron 530s intel 2 windows vista, black screen at startup than disk read error
Disk read error happens when there is a hard drive failure (sometimes in isolated spots and some times crital failure) if you have another computer, you can try connecting the hard drive as secondary and check if you can backup. The solution to this problem is to replace the hard disk drive.
Feb 03, 2011 | Computers & Internet
I have a HTC Touch GSM, after an error pop up it´s been resetted and now it shows only the first image (the black backgroung saying Smart Mobility in white) and stay freezed there.
Oct 08, 2009 | HTC Touch P3450 Smartphone
Vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
Sep 05, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
When i try to turn my computer on it wont even boot up it has a black screen that says a disk read error occurred press ctrl alt del to restart. then nothing happens. this computer has my life on it...
http://www.salvagedata.com/disk-error-failure/
please read that article
There is a way I have done in the past and its remove the old drive put a new one in install new operating system. and see if I can manage to get my info off the old drive once the new drive is completly installed.
and if that dosent work I put the old drive on Ice, well a ziplock bag then into the freezer. oddly enough its saved me more time then not. I manage to get all my data off the hard drive and then finally format the old drive then it works again most of the time.
im not too sure what to suggest I wouldnt do what I do. cause its not a actual method of troubleshooting this issue.
read the article and see what you think.
if you dont want to loose any info seriously pick up a 1 gig or 2gig hard drive from a computer shop for 5 bucks install the os and manage to get your data off. well whatever size you would figure you would need also ebay is a good chance too for cheaper hard drives.
Aug 05, 2008 | Computers & Internet
Hard drive problem
There is no problem on the hard disk.. It's either the memory or the motherboard is having a fault. Try cleaning the memory contact point with a pencil eraser and try again....
Check also the voltage of the battery cell on your motherboard it should read higher than 2.8V DC, replace it if below 2.8.
Hoping a Fixya result on my suggestion... Anyway, post me back if nothing happens, we will fix it...
Feb 04, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
My hard drive does a clicking sound
What?s going on: Your hard drive is suffering from read errors. It?s going to a spot on the hard drive to read some information it needs and can?t read it. Once that happens the built-in procedure is for the hard drive controller to put the read heads back into the home position (the clicking noise you hear) and go back out to the section it couldn?t read before. It will continue to do this a set number of times and then usually give you a read error or a blue screen of death. What to do: -You can try reformatting your hard drive in the attempt to get the operating system to block out the sectors it can?t read. Sounds nice in theory, however, if you have bad sectors developing others will probably follow which means you?ll have the same problem again. If money is a serious issue you can try this but chances are this will only be a temporary fix. -Replace the hard drive and reinstall your operating system. At $80 this is likely to be your best option if stability is your primary concern. Let us know if you have any other questions and please don?t forget to rate this post.
Jan 30, 2007 | Maxtor DiamondMax Plus 9 200 GB Hard Drive
Copier making black backgroung after 3-4 prints.
Possibly your drom is no longer discharging properly. This could be caused by bad drum, bad or dirty erase lamps.
Dec 19, 2006 | Minolta EP4000/5000 CS/PRO Copier
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
