Question about Pass & Seymour / Legrand DFB600-M 600VA Fluorescent Preset Dimmers Single P
Does the hot wire go to the top screw on the switch or the bottom?
  • 43,501 Answers
Unless it is a switch that is lighted it does not matter...it will work either way...
heatman101
Posted on Sep 01, 2010
CSB115STA cooper single pole light switch install diagram
Neutral wire is NEVER connected to a switch:
Your box may not have a neutral wire, but still the box can have a white wire.
Copy following link for switch wiring diagrams:
http://waterheatertimer.org/How-to-wire-switches.html
Dec 03, 2011 | Cooper Lighting Electrical Supplies
I have a red, black, white and ground wire from the house. I have a red,black, white and green wire on the switch. What do I connect to what?
seems like you have wiring for a three way switch you need a three way switch to make it work , the way i do it is the black and white are hot red is a traveler wirewhite will be onb top the others on bottom there should be a screw on top two screws on the bottom see if the white is tag with a peice of black tape on it to tell you the wire is hot, good luck
Sep 06, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Replacing a double light switch, the old switch has 6 terminals. The new metal double switch has the same but both commons are at the top where as the old one had common top and bottom. The L1 and L2 are...
You question invites guessing.
Switch is not identified.
Screw terminal colors are not identified. Load is not described.
Maybe you have double switch where 1 switch is single pole and 1 switch is 3-way.
This type switch is wired differently depending on location of hot wire supplying power to 3-way switch.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#TM813
Electricians don't guess, they test.
Use multi-meter and continuity tester from home center.
Screw color is very important for wiring electrical devices.
First step is to note where each wire is located on old switch, hopefully doing that before removing wires on old switch.
And note what color screw that wire connected to.
Take a photograph.
Then determine what each wire does by testing and process of elimination.
Compare screw colors on old device to screw colors on new device.
Use continuity tester on old device and on new device to check screw-terminal relationships.
For additional help, add a comment after testing the screw terminals as described above.
Sep 02, 2011 | Cooper Industries Cooper Wiring CS220W AC...
I have a leviton combination (2) switch... I want each switch to (naturally) operate (2) different lights - all (white) 4 neutrals are combo in a wire nut and feed is going to the right side top brass...
Don't break away the tab.
It sounds like you have Hot wire connected to wrong side of device.
Separate wires. Turn power ON.
Test each wire to bare ground.
Tester lights up on Hot wire.
Hot connects to brass screw(s). This will feed power into each switch.
Wires going to Load (lights) connect to each silver screw.
Feb 19, 2011 | Leviton 002-1754-W Dual Rocker Switches
How to replace a switch combination receptable to a middle of the run duplex receptable. the switch combination have 3 screws on rt side ( brass on top , black screw , tab, black screw. left side grd...
Don't hardwire the disposal. That's against plumbing and electrical code. House will not pass inspection.
That being said.
Note which wires were connected on same screw.
Do not untwist any wires..
Separate individual wires for testing.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Hot connects to Brass screw on ordinary receptacle.
Hot is identified.
Test Hot to each other wire, except bare ground.
Tester lights up on Neutral. Neutral connects to Silver screw on ordinary receptacle.
Load wire goes to disposal.
To put power to Load, then Load wire also connects to brass screw along with Hot wire.
Feb 19, 2011 | Cooper Wiring Devices Combination Switch &...
I have the 691pass&seymour toggle switch/outlet, the way the electric was wired over 40+years ago does not look right? but I would like to install this new switch. on the old switch on the right side...
Thank you for the clear description of your P&S device.
You need to test your wires.
We are looking for the Hot, Neutral and Load wires.
Your old switch has two wires.
One of these wires is the Hot (I suspect 100% that the wire that comes from the other wires that are twisted together is the Hot)
The other is Load
Separate the old switch wires and turn on power.
Use ordinary tester.
Test each wire to metal box and see if the box is grounded.
Tester will light up on Hot wire.
You can also test each of the old switch wires to the other wires in the box.
1) Hot: Once you determine the Hot wire, this wire will connect to the P&S device:
Hot connects to the brass screws on right side, just as you said ... and these screws are on opposite side from silver screw.
2) Load: The wire to Load connects to brass screw on top left, which is on same side of device as silver screw. This screw sits opposite the P&S switch.
The last wire is the Neutral.
Test your Hot wire to all other wires in the box.
When the tester lights up, that is the Neutral
3) Neutral connects to silver screw which will complete the circuit to the P&S receptacle.
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Nov 08, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
Hi...do I run the exposed copper wire between the two poles on the left hand side of the switch....e.g. the middle screw and the bottom screw.? Thanks
No there are two screws that are tied together on the right side that is the side the hot wire ties to. The other side that has two screws one at the top and one at the bottom. This is the screws that the wires from the lights will go to
Sep 05, 2010 | Leviton 5634 Dual 1 Pole Switch Decora...
I am replacing a single pole switch that contains two rockers - one controls some lights, the other the garbage disposal. I am using a Levitron 5634; when I removed the broken switch it had 3 wires...
You have the hot wire on the wrong side of the switch. The side of the switch with the fin is where you put the hot wire. On the other side of the switch where there is no fin is where you put the other two wires one on each screw. When you have it wired that wat your switch will work like the old one. Also if you would like the lights to come on with the top part of switch. But works with the bottom switch you just need to switch the two wires from top to bottom.
Jan 20, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
I have a 12/2 w ground source. I want to use a Leviton 5224 combination switch to control a double plug. The top swithch for the top plug and the bottom switch for the bottom plug. I will use 12/3 with...
from power source black/hot wire to switch, white and bare/ground wires wire nut white to white bare to bare. run then to outlet white wire to silver screw bare to green screw. black wires to outlet from top switch to top of outlet bottom switch to bottom outlet break off fin on hot side of outlet should be brass screws dont' forget to turn off power before you start.
Nov 04, 2009 | Electrical Supplies
Installation Question
Make sure you are using three way switch's and not plain on/off switch's there is a difference. if you are using 2 plain on/off switch's the lights will only come on when they are both off. Find the power side with a meter. Put the meter on V A/C and hold the leads. One on the white wires that are connected together seperate from the switch. Id the hot wire. Now, go to the other side and id the hot wire on the other switch. Disconnect everthing on both switches. Find the hot wire again and on the side that the hot wire is on, put that hot wire on the bottom black looking phillips screw. Put the other two on the top of the switch. Go to the other switch and put the hot wire (black) on the top. Take the bulb out of the socket and put you meter on the beep continuity. Place one in the socket and find the other by oplacing the probe on the other two wires one at a time. The one that beeps goes on the black phillips screw and the one that doesnt goes on the other screw on the top.
Aug 27, 2008 | Leviton Decora Gray Rocker 4-Way AC Quiet...
Pass & Seymour / Legrand DFB600-M 600VA Fluorescent Preset Dimmers Single P Logo
503 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
