Question about Sharp CD-PC3500 CD Shelf System
CD BA 1600 stereo powers on after unplugging for about 15 minutes to the Welcome mode. But goes to Protect when you press the power button and won't respond to any buttons. Any ideas.
  • 15 Answers
SOURCE: Sharp LC-15AV4U 15 in. LCD Television
Sounds like a lamp error.... either a defective or broken lamp within the LCD1.gif panel itself, or you have a bad inverter.
Posted on Apr 02, 2008
SOURCE: Power button won't turn monitor off?
Alternative : Download Turn Off Monitor Utility from http://www.monitoroff.com
Posted on Sep 22, 2008
  • 899 Answers
SOURCE: Remote's menu and input buttons, and television Input button not responding
well the problem sounds like it could be the IR sensor on the tv or somthing in that circut that is failing or the EPROM chip that controls : Vol up/down , Channel up/down , Power on/off ,Menu , Input selection , ect... is failing, thus this will trigger the protection circut to shut the tv down. this kind of a problem only gets worse and can dammage other components if not repaired soon so it will need testing to determine the exact cause
Posted on Oct 14, 2008
  • 4234 Answers
SOURCE: My sharp Stereo is stuck in '' protect'' mode
Protect mode is not something that a reset will fix. Basically it indicates that there is a problem with the final output stage of the amplifier. Normally this indicates that the output transistors are defective. In most boomboxes, the amplifier is a single IC. If you can post the model number, I can provide you with the required part and cost.
Thanks,
Dan
Posted on Mar 25, 2009
  • 4234 Answers
SOURCE: Sharp CD-BA300 stereo system went into Protect
These units use AMP-PACs for the final amplification stages. This part is defective. The protect message indicates that there is an internal problem and the unit is shutdown to prevent further damage. The part numbers are listed below with the costs. These parts can be purchased from tritronicsinc.com. Use the guest account to access them.
Parts:
VHISTK40271-1 $58.28
VHISTK4029S-1 $63.32
Dan
Posted on Nov 17, 2009
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
What is "Press Power Protect"?
Hi Lois,
Stereo sytems have a protection circuit that alerts you by displaying "protect" when there is a electrical short circuit detected in the system, the most common short happens in a speaker, try disconnectig the speaker wires of both speakers(all speakers) at the back of the system, then play the CD or cassette player(although you will not hear anything with the speakers disconnected) and see if the unit goes into "protect" mode if the problem is still present then you have an internal short circuit and the system will need to be sent in for service or replaced(depending on age,repair costs). I would not recommend investing more than $80 into repairs. Now, if the unit does not go into "protect mode" then one of the speakers or speaker wires is shorted,be sure you check the conndition of the speaker wires before you replace the speakers, then you can replace the speakers(in a pair) and you should be back up and listening! Good luck and Merry Christmas !
Dec 03, 2009 | Sony MHC-NX1 Shelf System
Sony LBT W5000
According to Page 46 of the LBT-W5000 Operating Instructions:
"The display stars flashing as soon as you plug in the power cord even though you haven't turned on the system (demonstration mode).
Press DISPLAY (for LBT-W5000 / W300 / XB700 / XB500) or DEMO (STANDBY) (for other models) while the system is off. If the system is in the Power Saving mode, press POWER SAVE / DEMO (STANDBY) (for LBT-W5000 / W300 / XB700 / XB500). The demonstration appears automatically the first time you plug in the power cord, or if there is a power outage lasting longer than half a day."
I tested this today, as my LBT-W5000 was in Demonstration Mode. It definitely works. The only catch is (at least on the W5000), and it's a minor one, you have to reset your clock afterwards.
May 29, 2009 | Sony LBT-W5000 Shelf System
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Sharp Stereo- Protect Mode??
Try plugging in a pair of headphones. I tried it without the speakers connected and since it found the headphones and they were OK the system came out of protect mode.
Nov 21, 2007 | Kenwood XD-655 CD Shelf System
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Apr 15, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
Sharp CD-PC3500 CD Shelf System Logo
95 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
