Question about Eureka 4467AV Upright Vacuum
Changed belt in my vacum and it is now smoking and i smell burnt rubber
  • Eureka Master
  • 43,501 Answers
Check the brush and make sure that it seated correctly...between pulling on the new belt and getting the brush back into the slots sometimes it will bind up...
You also will now want to put a new belt in now... the belt is toast if it smoked...
heatman101
Posted on Sep 01, 2010
Burnt rubber smell when vacuuming
This could be a few things:
A. If your model has a floor selector switch (Bare floor/tools - Carpet) your clutch could be worn. (there is a rubber clutch pad between your cam and roller shell) - Fix would be to replace the clutch pad and belt.
B. If you don't have one of the above models, your belt could be stretched. The belt slipping could cause a rubber burning smell. Fix - Change belt.
C. Have you got any new carpet you are vacuuming or have you moved? Some of the newer style frieze carpets can cause burning rubber smell. The fibers of the carpet are longer and cause the brush to slow down causing the belt to burn. (Imagine brushing long hair with a thick brush, the hair easily gets tangled in the brush, same effect with this carpet.) Some of the newer rugs can do this as well. Some newer carpets with the thicker felt backing and/or the "pet padding" under the carpet can too. it doesn't allow enough air to flow through causing the cleaner head to seal itself to the carpet causing a burning smell. The fix is Move to another home, replace your carpets or replace your vacuum. The vacuum is the cheaper option but be cautious as most vacuums now do this with these carpets. We have had really good response from customers using the Simplicity Tandem Air models, (Synchrony and Synergy models.)
Hope this helps, if you need to talk further feel free to contact me.
Tim
TheVacCenter.com
Mar 13, 2013 | Simplicity Vacuums
When using the vacum it is giving off a bad smell. We changed the bag and the filter any suggestions?
Is it a smell like burning rubber. If it is your rubber drive belt has to much stress on it and is slipping. The friction is causing it to get hot and melt.
Aug 27, 2010 | Kenmore Vacuums
After a few minutes of using my vacume it starts to smell like burnt rubber. like the belt is burningthe only belt I can see looks fine and is turning the brush
but how tight is the belt and how easy is the brush to turn? if the belt is slopy it will slip on the motor drive spindle,,,and it will get very hot then,,, also if the brush head is tight that makes the belt slip too,
Aug 11, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
My hoover really smell bad, changing the bag and washing out the cylinder have not stopped it
Are you smelling a burnt rubber smell? If you are, you need to replace your belt. You can get hoover replacement belts here:
http://www.vacbelts.com/index.htm
Oct 24, 2009 | Hoover Vacuums
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Smoke and bad smell coming from the base
you need a nw belt but before you change the belt clean the burnt rubber off the motor shaft or your new belt won't last
Apr 03, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Fantom Lighting Power Head
The red light tells you that that there is a clog, either in the hose or down by the brush roll. The smell if it is rubber smelling, then it is the belt and maybe the brush roll. If it is an electrical smell, then probably the motor. But parts for these are always available, they went bankrupt several years ago and aren't in business anymore.
Mar 24, 2008 | Fantom Vacums Lighting Canister Vacuum
Eureka 4467AV Upright Vacuum Logo
134 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
