Question about Duke E101-G Gas Single Oven
How do you light the pilot light on a duke e convection oven?
5 Suggested Answers
  • 106 Answers
SOURCE: hi,
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Posted on Jul 29, 2010
SOURCE: convection oven single,table top
got it,thank you
Posted on Aug 06, 2008
SOURCE: Duke Convection Oven won't heat past 250 degrees
Most likely a heating element.
Posted on Nov 08, 2009
  • 110 Answers
SOURCE: My covection oven does not heat up once food is put in
on the gas valve there is an adj. for the pilot size, maybe too small , would try increasing the pilot and see what happens.also the thermocouple might be on the way out ,you might want to replace that and try oper. go with thermocouple first, then try pilot size dont forget to vote tks. monomoy
Posted on Jan 11, 2010
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
I have a gas garland convection oven 10-15 years old. I see the red button to relight the pilot light but I can't find the pilot light itself. Can you tell me where I should be looking?
On the main bake burner is going to be a small pilot burner,got to lift off the oven floor to get to it. It is going to look something like this picture and is attached usually to the side of the main burner.To light the pilot,push that red button light the small pilot burner..hold in the red button for about 20 seconds..release the red button..pilot should be on..if goes off the thermocoupler is going to be in need of replacement
Aug 26, 2011 | Ovens
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
Jul 29, 2010 | Duke 59-E4Z Electric Single Oven
I have a defective flame sensor on a duke oven, I need to know the best way to remove it to replace with a new one. It does not appeear there is enough room inside to access it.
it does require removal of entire burner assembly. which is not all that hard to do but a bit time consuming. fittings for 2 burners and pilot must be disconnected and 3 screws on front of burner assembly. unit will then pull right out allowing access to flame sensor bulb. hope this helps!
Apr 22, 2010 | Duke E101-G Gas Single Oven
Why should the cooker burn that hot, when you can cook most things at a max 220Celsius
Sep 27, 2009 | Duke 59-E4Z Electric Single Oven
Feb 20, 2009 | Hobart HGC202 Gas Single Oven
Duke E101-G Gas Single Oven Logo
131 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a Duke Oven Expert? Answer questions, earn points and help others
