1. To obtain the driver, go to ftp://ftp.vidar.com/pub/sti drivers/ and download "autocd.exe".
2. Run "autocd.exe" and the contents will be extracted to a folder.
3. In the Windows Control Panel, open the Device Manager (Control Panel-> System->Hardware Tab->Device Manager) and select the Driver tab within the Vidar Scanners properties.
4. Click on "Update Driver" and browse to the STI folder (unpackaged from autocd.exe).
Comments:
May 14, 2008
- Actually, line 3 should read:
In the Windows Control Panel, open the Add Hardware and select ADD AN IMAGING DEVICE. Follow the prompts.
Ignore step 4.
Those instructions are for updating the driver, which I imagine you do not have installed.
I need a hendheld pen scan
suitable for XP and editable on word,
to save especially half of the...
(More)
to save especially half of the lines not the all page,also it should write-
I need wireless one,with large memory,which can run on batteries I can recharge on the USB port.
do ou reccommend anything please?
I m going to use it in Europe
on Bugarian and Turkish
thanks a lot
my fingerprint reader is not recognizing my finger print and I can not remember my password to log...
(More)
my fingerprint reader is not recognizing my finger print and I can not remember my password to log onto windows!
A320 just arrived. Am using on a stable XP box. When attempting a scan, the scanner gets no further...
(More)
A320 just arrived. Am using on a stable XP box. When attempting a scan, the scanner gets no further than "calibrate scanner" then goes to Generic Error. Tried a few different means to scan - same result. This is not thrilling when it seems to be bad out of the box.
I launch Image zone then select the scanner device, then click preview scan. A message window pops...
(More)
I launch Image zone then select the scanner device, then click preview scan. A message window pops up: "cannot initialize scanner" HP Scanner preferences
I've double checked the electrical and USB connections; also the Lock Switch. I've uninstalled and...
(More)
I've double checked the electrical and USB connections; also the Lock Switch. I've uninstalled and reinstalled the scangear toolbox. When I try to run the copy or fax function, I get the following error messages: (1) "Unable to open TWAIN source Please check connection Then re-start Toolbox" (2) "Unlock the Lock Switch and turn the scanner on again. Scanner driver will be closed." I've tried everything I can think of but I'm not technologically savvy.
