Question about Haier Refrigerators
My refrigarator is five months old and just stopped cooling
  • Haier Master
  • 43,501 Answers
You should still be covered under the manufacturer warranty...
Call them and insist on a new one or this one fixed WITH an extended warranty...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
Msd2657heb------once every month my frig and freezer stops cooling the frig is on but not cooling---i unplug frig wait 5 minutes then it starts cooling again-all most like it is in a defrost mode that...
Hi.
There is need to test the defrost system and the electronics. If the fridge restarts in five minutes, then that is not enough to defrost. Problem may be electronic temperature control. Compressor start capacitor is also worth a look.
Let me know if you want more help on this.
Regards.
Ginko.
Mar 13, 2011 | Maytag Refrigerators
My chest freezer is running and feels cool on the inner four sides but not freezing anything. Just keeps things cool, but they don't freeze up.
dear sir ,
first make sure your freezer,s condensore unit is well clean if its good clean then contect to your service technician for refilling refrigarant .i think refrigarant gas is not good amount in your freezer.or freezer has been leak from somewhere.
hope answer the question
thank you
please vote!
Jul 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
My Whirlpool Refrigarator isnt cooling or freezing. Its running but there is no cool air on either side. Ive adjusted the temperature control to the coldest setting but still nothing...what could the...
Pull the lower front panel off. Inside you'll see a round small timer with a screw slot in it. Turn the screw slot slowly to the right (clockwise) only, until you hear a slight click. Wait five minutes and feel the walls of the freezer, they should be getting cold by now. If so, you need a new defrost timer. Thank you, Dana
Mar 26, 2010 | Whirlpool GD5SHAX Side by Side...
I have a whirlpool refrigerator side by side.The problem that i am having is that the freezer side cool's but the refrigarator side does not cool at all.
Please check your door gaskets and in case it is in bad shape do change it immediately. Or even a block in the system could result in partial cooling.
Jul 06, 2009 | Refrigerators
Not cooling
Unplug it, and don't turn it on anymore. Doing so can damage the compressor, and I hope it is not damaged already. This will cause the compressor to overheat, and fail. You can buy line tap, and then buy one of those 134 adapter. Check to see if it has freon in there. Refrigarators today uses 134 and anyone can buy it. Locate the low side which is the larger tube coming out of the compressor. Screw in the tap, which should poke a hole on the line. Dont worry a tap do not leak, and I have used them many times.Once in place push the valve if there is any freon in there. if there is none then there is a leak somewhere. Find the leak and repair it first. You can buy a cheap propane torch for about 12-20 bucks, along with flux, and some solder. make sure you clean the copper to be repaired first with a wire brush. Once the leak is repaired, you are now ready to put the 134 refrigerant. An average refrigarator usually take a little more the half a can of 134. Putting too much will not make it cold enough. Well good luck hope this hepls.
Jun 27, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Weather King 10AJA6001AH Air Conditioner with bad compressor
If it is five years old it is either right in or out of warranty a service tech can determine this through the serial number. If not the unit is only a little bit more to replace than the compressor. A replacement compressor is only warrantied for one year verses a unit replacement with five years on the compressor and one year parts and labor.
Oct 04, 2008 | Air Tools & Compressors
Refrigerators Logo
47 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
