Question about CTX S762A 17" LCD Monitor
Hp pavilian f1703 monitor
When i hit the menu button to take the contrast and brightness button to go off the monitor it does not go away I have to stick a piece of paper in the control button so it is not on the screen
  • trace4263 May 09, 2008
    do I have a reset button?
Just press the MENU button and the BRIGHTNESS button "simultaneously", and ....... magically the stubborn brightness box went away for good !
Posted on Sep 27, 2012
    Guru:
  • 859 Answers
Press the menu button again (or when done adjusting) and it will go away.
Posted on May 10, 2008
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
I have an HP pavilionf1703 monitor. Two blue squares on
If the cursor is hidden use the keyboard: Press the TAB key and cycle the options. When you reach the one you want press ENTER
Hope it helps.
Aug 30, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp pavilian a1700n will not show anything on monitor. Power light comes on fan is on at processor
the screen might be worn out. or connecots inside the computer could have gone bad. make sure the contrast/brightness settings haven't been changed.
Aug 10, 2009 | HP Computers & Internet
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Viewsonic VG2021m contrast/brightness menu won't go away
I had same problem. The solution I got was to unplug power cord, and hold down each switch on monitor for 30 secs and switch on. IT WORKED! Hope it helps you too.,
Fred
Apr 12, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Hp.f1703 in centre of screen small blue instructions regarding OSD and default settings for contrast appears from time to time without me pressing the buttons. This is very annoying whilst working.
this may be your monitor settings popping up. i had a monitor and limmitted space and the keyboard kep hitting the menu button on the monitor, it was very annoying with the menu popping up while i was gaming, untill i figured it out.
moving the monitor back a few inches solved the problem
Oct 24, 2008 | Computers & Internet
Whereabouts and meaning of OSD
OSD stands for On Screen Display. You get to it by pressing the Menu button on the front of your monitor.
Here's a link to making adjustments...and unlocking the OSD:
HP f1703
Oct 18, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Menu option
stuck in adjusting button?
Oct 11, 2007 | HP f1905 19" Flat Panel LCD Monitor
CTX S762A 17" LCD Monitor Logo
167 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
