Question about Refrigerators
When i close the freezer or refrigerator doors the refrigerator makes a strange noise. like something is working hard to create a vacuum in order to shut tight???
  • 21 Answers
Could be just vacuum caused by temp diference if you shut hear noise then try to open quickly but is stuck shut try pushing seal so it breaks from surface. if door opens easy then this is normal on some makes. also be aware if frot free when you close door fan comes on. May be getting noisy bearings.
Posted on Sep 01, 2010
Creaking noise after refrigerator door is closed
only thing I can thing of is the slight vacuum caused by the quick temperature change when the warm air that enters when the door is open is trapped after closing the door. As it cools it shrinks and creates a mild vacuum which should dissipate after a few seconds. The creaking is probably the sound of the pressure regulating between the fridge and the room. Might indicate a problem with one of your seals but more than likely is not a concern.
Mar 27, 2014 | LG LFC25760 French Door Refrigerator
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
Weird (Pressure Release) Noise After The Door Has Been Closed
The freezer being closed up tight and so cold can create a negative pressure inside. This negative pressure will cause the door to be very hard to open and could pull the door closed too quickly. Most manufactures today use small air valves the open and release as the door is being opened and closed. They are most often found on the bottom of the door itself or sometimes in the cabinet behind the back wall.
The noise is perfectly normal, my wife says it is there to alarm her when I am eating too many ice cream bars.....
May 03, 2010 | Frigidaire 14.1 cu. ft. / 399 liter...
Freezer on bottom is cold,refrigerator on top is warm. 2 days before failure there was a vibration noise intermittently between fridge and freezer that stoppped if freezer door was shut hard
This is a little strange to hear but something caused the vibration. Closing the doors hard or soft may make big changes in sound because of pressure change. I just want to know if the compressor is purring away without overheating. Anytime there is a restriction in ventilation the evaporator fan will struggle to push the air to the freezer and enough to refrigerator side to maintain safe temperatures. On the bottom even if the fan stopped the bottom would work because it is below and cold is heavier than warm. I will look over your parts breakdown to see what vent, dampers or fans that may cause this, work with me on this and I will help you solve this. Thanks Sea Breeze
Jan 21, 2010 | GE Profile PDS20SFS Bottom Freezer...
Model pds22mbsacc, bought control board refrigerator had stopped cooling, lights still on, put new board in refrigerator, refridgerator and freezer worked but with a strange noise, then refrigerator...
Sorry for your troubles. The fact that you replaced the control may be unfortunate, that`s still to be decided. Was this the symptom (cold freezer, but not cooling in fridge section) you had previously ?
In any event, the important part of all this is the freezer. As long as it is working, relative to how close to correct temperature, i.e. 0 to -10 degrees it is, you`ll never need a control. As long as it is freezing, that in itself indicates you simply have an air-flow problem. You`ll want to check the evaporator fan motor located on the back wall of the freezer (you may be able to see it through the grill like cover). Verify it is rotating or if it is not. You may need to manually hold the freezer door switch in the closed position to make it run (assuming the fridge door is closed on some units).
Once you determine whether or not the fan is running you`ll then either need to replace it, or what else is blocking/obstructing your air flow into and from the fridge section.
Hope that help`s you move forward. Let me know.
Good luck.
macmarkus :)
Dec 02, 2009 | GE Refrigerators
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Kenmore door seals for a few seconds.
There is a vacuum purposely created which closes and seals the doors tight when you close them. After a while the p[ressure inside stabalizes and you can open the doors. This is a good thing!
Apr 08, 2009 | Refrigerators
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Refrigerator suction/vacuum noise, rear section when freezer door is closed
there is no suction system. flush your defrost drain tube with boiling water and a turkey baster. should get some pretty nasty sludge out and sound will go away.
Dec 28, 2007 | Whirlpool GS6SHAXMQ Side by Side...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
