Question about Mitsubishi 915P061010 Projector Lamp
I ordered replacement lamp for Mitsubishi model #915p061010. What is the best way to replace? are there any step by step directions so I don't tear up my TV trying to replace a lamp?
  • johncscarbor Sep 01, 2010
    my tv model is WD-65733..... i don't think what you wrote applies to me. do you have anything for my tv model? please help, thanks,
  • Mitsubishi Master
  • 11,800 Answers
Just follow the manual. Here it is
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-65733.pdf
The instructions on how to do it can be found on page 61
Posted on Sep 01, 2010
  • 2,272 Answers
This guide is for replacing Mitsubishi DLP lamps with these models:
- WD-52631
- WD-57731
- WD-57732
- WD-65731
- WD-65732
- WD-y57
- WD-y65
Step 1: Unplug TV and locate lamp housing unit on the back of your Tv ( If you have trouble locating it check your user manual).
Step 2: Unscrew the two screws on the unit and remove gently. The two plastic tabs need to be pushed down on each side of the housing unit to allow the housing to pull apart . Remove the lamp by first removing the two screws that hold the lamp connector to the housing. The four metal tabs with screws holding the lamp in place need to be removed. The lamp can now be seperated from the housing.Look how the lamp is positioned in the housing and put the replacement in the same exact way.
Step 3: Replace the four metal tabs and screws to hold the lamp in place. Reinstall the lamp connector by placing the lamp in the previous place and fasten it with the two washers and screws. The post on the top of the lamp is very fragile so be careful. MAKE SURE YOU DO NOT OVER TIGHTEN THE NUT ON THE POST.
Step 4: Put the housing unit back together and reinstall into the back of your Tv
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
915P061010
that part number is for the Lamp assembly. How can I assist you with your set. Please respond to this same post for further assistance.
Mar 22, 2013 | Mitsubishi WD-65733 65" HDTV
Lamp 915p061010
You can get that replacement lamp along with free installation instructions from www.tvrepairworld.com under the Mitsubishi DLP lamp catagory.
Oct 26, 2012 | Mitsubishi 915p061010 Tv Lamp 915p061010
My 65 in tv turns on but the screen stays black
I am sorry to here about the problem that you are having. I will be happy to help you in any way possible.
It seems that the lamp has went out in you TV. You need to order a new lamp from Mitsubishi, the part can be ordered on the web at
www.mitsuparts.com , or by calling 1 800 553 7278. The part number of your lamp is 915P061010.
Now you will have to follow step by step instruction below in order to replace the lamp.
  1. Turn off and unplug the TV
  2. Located the a little panel on the back of the TV held on with two screws. This is the lamp compartment.
  3. Once you have removed the door, pull out the lamp assembly.
  4. Remove the lamp
  5. Inspect the lamp assembly as this may need to be ordered as well
  6. If it looks good clean all dust and dirt with a cloth, vacuum or can of compressed air
  7. Install your new lamp in the lamp assembly
  8. Install back in the TV and put the door on as to assure not to get burned or shocked
  9. Plug back in and enjoy the TV
You should also inquire with local recyclers as what to do with the lamp and it may contain gases that are not good for the environment.
I hope that I have been of some assistance and look forward to answering any question you may have in the future. Thank you for using FixYa.
Mar 02, 2011 | Mitsubishi WD-57733 57" HDTV
How do I replace the lamp in a Mitsubishi WD65833 model
915P061010 part number for lamp, remove Philips head screw from lamp door in rear of set. YOU will find the lamp under door. Pull out, install new lamp, reinstall Phillips screw. Plug TV back in.
should do trick
Please leave feedback
Feb 18, 2011 | Mitsubishi WD-65833 65" HDTV
The overall picture is not bright like it use to be. like about half the brightness. picture is fine just not bright
suggest replacing the lamp. when the lamps are reaching the end of their life the tv will take a long time to show a picture and you may see a drop in brightness. part number 915P061010 i would really suggest getting a mitsubishi original lamp there are alot of generics out there and they are junk. good luck
Jan 06, 2011 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
Mitsubishi 915P061010 Projector Lamp Logo
149 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
