Question about Dometic Rooftop RV Air Conditioner
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
  • Dometic Master
  • 43,501 Answers
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
Posted on Sep 01, 2010
My roof top duo therm a/c unit was working fine this weekend untill it all of a sudden stopped blowing air the compressor kicks on but the fan does not
check for the presence of voltage supply to the fan motor,if it has voltage,check the winding of fan motor if it has resistance base on its connections.if the fan is defective,perform a rewinding of coil
Apr 14, 2014 | Heating & Cooling
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
Turn my roof top ac on , fan runs but when compressor tries to run lights in camper dims 3 to 5 sec. don;t kick breaker off, any ideas?
You need to get a reading on the current draw of the compressor. Use a clamp on ampmeter to do this. Compare your reading with the data plate on the compressor. Your compressor may be getting ready to go out. You can also check the capacitor. If may be getting weak and need replacing. Another idea may be to install a hard start capacitor if the compressor is OK.
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Duo-Therm Brisk Air Model 59516.601 Ducted Roof Air w/wall thermostat
First of all, I think you mean 110 volts on your meter, not amps, just so we're on the same page. It sounds to me like you may have a capacitor problem on your compressor. I'll try to see if I can find you a part # if you have someone very experienced with electrical that can change it for you. they can be a little dangerous, so only someone familar with them should work with it. What the capacitor basically does is store voltage and uses it to help the big draw on start-up of the compressor, kind of like giving it a boost to get it started, and after it's up and running, all should be well if everything else is up to snuff. How old is the AC unit? Did it run well for you in the past? I'm asking this just in case it was a recent installation, with perhaps wrong size wire used. Should be minimum 12/2 , with 20amp breaker,if that means anything to you, or your mechanic.
Aug 15, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
604 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
