Question about Craftsman 20 Hp 42" Deck Lawn Tractor
When i engage blades my mower cuts off - Craftsman 20 Hp 42" Deck Lawn Tractor
  • 33 Answers
Most likely the seat switch make sure it is made.
Posted on Sep 01, 2010
  • Lloyd Carter Jul 05, 2011
    1 make sure the blades are free and not hitting the deck. You can make sure the blades are not bent by measuring them. (A) measure one side of the blade and then move the blade 180 degrees and measure again. (B) do this to all blades. If the measurement is off something is bent(blades, pulley shaft or deck.
    2 If #1 is free and clear you have safety switches to check, the seat switch opens and kills the motor when no one is in it and the tractor is in gear, the blade engage lever switch kills the motor when the deck is not down(not on all models) when the tractor is in reverse, when the tractor is in neutral but no one is in the seat. I would check for worn wires or loose connections before taking it to a dealer.
    Hope this helps.
Cutting blade won't engage
with unit off look under at deck and inspect cable and pulleys and belt adjust and or repair
Sep 28, 2016 | Garden
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Belt comes off every time I engage the blades
when changing the blades did you remove the deck and put one of the lift rods in the wrong place?
May 26, 2012 | Garden
Very bad vibration when engaging the blade
Bad vibrations when engaging blades is usually caused by an out of balance blade. Out of balance blades occur due to damaged and/or bent blades. The fix is to find and replace the offending blade.
Jul 19, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower blades not engaging
is the mower belt on the pulley ?
Jun 12, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
