My computer will not stay on, before it went off, said no battery detected. ordered new battery, and it did not mske my laptop come on. help
  • 808 Answers
Check ur psu and use reginout
Posted on Sep 01, 2010
Why does the check engine light stay on in 1999 sienna ...it went off after new battery was installed...thenon again
The engine light stays on because the computer has detected a fault code, when disconnecting the battery the memory is cleared but the fault code will eventually be set in the computer again until the problem is fixed, since there are many reasons for the check engine light to come on it is necessary to connect the vehicle to a diagnostic computer that can read the codes, this can be done at most repair shops, the dealer or some autoparts stores.
Dec 08, 2012 | 1999 Toyota Sienna
I bought this computer a couple of months ago and have used it about 3 times. When I turned it on, there was no power and it was fully charged before I went offline the last time. Now my battery icon...
Then, it should be FULLY covered under WARRANTY, either from the store from where you bought it, or from ACER.
> new battery from COSTCO
It's probably 100% fine; it's your laptop that is the problem.
Exercise the WARRANTY to get the laptop repaired/replaced, at NO COST to you.
Jul 25, 2011 | Computers & Internet
Sony Vaio VGN-FS315E......At first the laptop could not detect the battery, so i was using the charger only but with the battery inside for sometime.I switched it on one morning and the laptop went of...
The battery might be damage for the time of use or maybe you put in a inadecuate space, the computer works perfectly without the battery but if it doesnt occure and the computer dont works with out the battery and the charger dont supply the energy of the pc maybe you can try with a new battery and a new charger if it doesnt solve the problem your internal hardware is damage or your software is corrupted or damage too.
Oct 11, 2010 | Sony VAIO VGN-NR430E/S NoteBook
The power supply to my c640 has a green light that flashes when plugged into the laptop, if i unplug it from the laptop, the light stays steady and green, do i have aproblem, the laptop will not power up...
Is the battery charging when you plug the power supply? If not, while the battery and the power supply is plugged in go to BIOS, that will be F2 when your computer boots up, from there check on battery health or battery info you will also see the ac adapter if it's detected if it says unknown try to use another ac adapter if it is detected still try to use another adapter. If you still have the same problem after trying a new one. You'll need to replace the motherboard
Jan 31, 2010 | Dell Latitude C640 Notebook
A few months ago my Dell Vostro 1500 laptop started saying that my battery could not be detected. I bought this laptop new in October 2007 and did not extend my warranty. I bought a new battery and...
Normally the message means that the battery is bad and needs to be replaced. There is a chance the new battery you got was defective and went bad before its time.
The motherboard can be the problem, although it is not common for this to be the case.
I would try one more battery before thinking about a new motherboard, a new battery is under a $100 where a new mobo is several hundred, and usually this is a sign of a bad battery. If you disconnect the ac adapter and it stays on then it is using the battery, although it is reporting that it cannot see a charge. I would guess the battery malfunctioned and is not being able to be read by the laptop.
Sep 12, 2009 | Dell Vostro 1500 Notebook
Turn off actomatically, cannot turn on so far.
Your battery may be too low to allow charging it and "starting" your computer at rhe same time.
Remove the battery and clean the contacts on the battery and the laptop.
1. Plug in the laptop power adapter with no battery in the laptop.
2. Turn ON computer. It should stay turned on.
3. After Windows settles, insert battery.
4. The computer will stay powered on.
5. Allow to charge.
Sep 08, 2009 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
No battery detected reading on my toshiba laptop
If the laptop was purchased new in November, 2008, the laptop is still under warranty. So, contact Toshiba for repair or replacement.
If not purchased new in November, the battery would probably need to be replaced. Hope this helps.
Aug 06, 2009 | Battery Technology for Toshiba Satellite...
Toshiba satelitte adapter went bad ordered new one it wont work
If the old one works you have another power supply or wrong one.
Check the properties of your power supply.
Related to your issue you also may consider this:
1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Toshiba Computers & Internet
Wrong battery detected.
hmmm..interesting....you may need to download the system drivers, usually for bios or other utility programs. the compatibility issue with batteries, is based on the make/model being loaded into the listings from the sysadmin for your operating system.
www.hp.com
Feb 25, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
