Question about Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
TV not detecting remote control signal
I noticed a bunch of ther people have the same problem. Is there a part I can replace? I can't justify the cost of having it professionally repaired. Everything works fine on the TV, except for the remote.
  • darrenh Nov 10, 2008
    Yes my MW24FM1 seems to have the same problem. From time to time the 3 remotes (2 cable and 1 OEM) may turn the TV on, but then not work at all for a long time. The 2 cable remotes work fine on the cable receiving box (all functions), but not on the TV. I have reset the code in both cable remotes several times closely following the directions. I've even got the correct code via the remote (0060), but when recoded, the TV does not respond. As I said, the OEM remote does not work either. This sounds like the IR sensor that you suggested; would you agree? If so, is it all that difficult to install? Cost?
    Thank you for your time and expertise!
    Darren
  • 934 Answers
It's simply a defective IR sensor Toshiba P/N 72796410 and if you know how to remove the main board and have a soldering unit that is a bit more delicate than than the monsters they sell at rat shack, some solder and desoldering braid you just might be able to do it yourself...
Bill
Posted on May 09, 2008
My tv wont work with the remote i can turn on by hand but remote wont do anything it has new batterys and the red light goes on
TV brand?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
LG:
1) Test the remote:
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Oct 30, 2011 | Televison & Video
The remote control of my 26" LCD Tv does not wprk any more, so I need to either fix it or replace it, how and mhere. Santiago Fregoso 323 564-0675 ...
You need to find out if it is the remote or the IR receiver in the TV is bad.
www.remotes.com
Jul 14, 2011 | Element Electronics 26 in. LCD TV
Thought remote was broke, so bought a new one, still cannot use remote for tv & it is the remote for this model
What is the make and model number of this TV? LG TV?
www.remotes.com
LG:
1) Test the remote:
Jun 03, 2011 | Televison & Video
Cant control tv from remote
Lets find out first if it is the remote controller or the remote IR receiver in the TV problem.
New batteries?
www.remotes.com
Mar 24, 2011 | Vizio 42 in. LCD TV
Toshiba remote control CT90300 wot working at all desp;ite having inserted and checked new batteries, The TV is working fine when switched on manually. Had noticed for a few days that the volume conrol...
Let's find out if it is the remote or the remote IR receiver in the TV.
www.remotes.com
http://www.remotecontrolscenter.com
http://www.newremotecontrol.com/
http://www.replacementremotes.com
http://www.newtvremotes.com
http://www.everytvremote.com/
Mar 18, 2011 | Televison & Video
The tv does not respond to remote control
Batteries are good?
www.remotes.com
If it is in the TV, it may not be worth putting the money into old 20
Jan 23, 2011 | Broksonic CTVG-5472 20" TV
The remote control stopped working the tv is less than ninty days old. I replaced the batteries and the remote still did not work. I went to walmart and they said they could not do any thing about it ....
Let's find out if it is the remote or remote IR receiver in the TV is the problem, if it is TV then you should have it repaired under warranty.
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 14, 2010 | Element ELC-HS321 32 in. LCD TV
Polaroid FCM-1000A 10 in. LCD under counter tv I replaced the battery in the remote--still doesn't work, any suggestions?
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Jul 07, 2010 | Polaroid FCM-1000A 10 in. LCD Television
Remote control will not work for my blu ray dvd
Sounds like your DVD players infrared receiving sensor(eye) has gone bad, a rare occurance but I have had that fail in other electronic units before.This would require you to send it in for service but the cost of the repair may justify just replacing the unit. Good luck !
Nov 29, 2009 | Televison & Video
32PW878 don´t replay to the remote control orders
You are checking signals at the micro in the TV set? I would first suspect a noisy remote receiver then before replacing other costly items.
Apr 19, 2007 | Philips 32PW8608 32" TV
Toshiba MW24FM1 24 in. TV/VCR/DVD Combo Logo
173 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
