Question about HP 12c Calculator
How can I cange to a "normal" view of numbers instead of a power of 10? Thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Press f followed by a digit for the number of digits to the right of the radix point you want to see.
Posted on Sep 01, 2010
How do i change the mode on my Casio fx-82au plus calculator?
Press SHIFT [MODE] to bring up the mode screen. Press 8 for NORM, then 2.
Bear in mind that if the magnitude of the number is too large or too small the calculator will switch to scientific notation anyway. For example, if a number has twenty leading zeros then it won't fit on the display unless it displays it as a power of ten to the negative twenty.
Apr 02, 2012 | Casio Office Equipment & Supplies
Wont let me do anything looking for f1 to set time and date
first remove the power and check the c mos battery for 3v if the battery have no voltage cange the battery also look for the jumber pins in your motherboard near the c mos battery and bios you will see two pins shorted with an juber move the jumber to the third pin normally the jumber setting are 1 and normal 2and 3 clear c mos
Oct 30, 2011 | Toshiba Computers & Internet
Serial Number:1045-1090-6246-8353-3166-2968 Activation Number:5654-5982-2199-6188-2262-1478-4063 Activation Type:Normal: 194:13 I need Authorization Code,please help me! Thanks!
Serial Number:1045-1090-6246-8353-3166-2968Activation Number:5654-5982-2199-6188-2262-1478-4063Activation Type:Normal: 194:13I need Authorization Code,please help me! Thanks!
Jan 18, 2011 | Adobe Computers & Internet
I have a Hamilton Beach 0.9 Cubic Feet 900-Watts Digital Microwave Oven and I can not find out how to change the power setting for cooking.
Assuming its the same as my Hamilton Beach, you first enter the cooking time, but don't press start yet, instead press power, then a number button 1 - 9 for the power level 1 for 10%, 2 for 20% etc. THEN press start as normal
Oct 29, 2010 | Microwave Ovens
How do I cange the routers MTU?
Go to WAN setup
Go to MTU size
Enter there the value Then Apply
Reboot
Cheers. U R Done!
Please RATE the answer
Thanks
Good Luck
Jun 17, 2009 | NetGear WGR614 Router
Changing the color of my screen display
how do i change my blue screen back to normal
Sep 27, 2008 | Corel WordPerfect Office 12 Standard...
Convergence
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link:
Feb 21, 2008 | RCA HD52W66 Projection Television
How to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Dec 25, 2007 | Optics
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
HP 12c Calculator Logo
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
