Question about Maytag MAH8700A Front Load Washer
Washer vibrates and walk in excess - Maytag MAH8700A Front Load Washer
  • Maytag Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Sep 01, 2010
Vibrates when it spins
Here are a few quick facts on washing machine vibration.
  1. All washing machines and dryer vibrate. Dryers usually have less vibration than washers because the load is only wet clothes (as opposed to a drum of water and clothes). Front loading washing machines cause high frequency vertical oscillation while top loading washers usually have horizontal oscillation.
  2. Almost all front loading washing machines are not recommended for use on standard joist-construction floors (most common floor type, compared to a concrete slab sub-floor). Manufactures like GE, LG, Maytag, Samsung, Whirlpool, Kenmore, Bosch and more, all recommend installing a pad like Silent Feet under the washing machine to absorb the vibration.
  3. The only alternative to using Silent Feet pads to prevent structural damage is costly upgrading of the sub-floor. This usually involves adding a second layer of plywood sub-floor and adding sister boards to the rafters that support the floor. But even this won't reduce the amount of vibration noise that you hear. Sub-floor upgrades can cost thousands of dollars.
  4. Vibration can also cause appliance "walking" (unwanted movement) usually during the spin cycle. Simply installing a pad designed to prevent walking can solve this problem and mean that you'll never have to reposition your washer after every load again. Both Original Silent Feet and Anti-Walk Silent Feet prevent walking, however for washers that move a lot or stacked units it is recommended that you install Anti-Walk Silent Feet for the best results.
You were not specific in either type or model. I hope the above information helps. Also, the size of the loads plays a great part in how a machine functions. have a nice day
You wer
Dec 16, 2013 | Kenmore Washing Machines
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
My new Maytag Bravos HE top load MVWX500XW vibrates during spin, is this normal?
from the way you describe the issue it sounds normal, all washers vibrate at least a little or alot (depending on the balance or unbalance of the load) if it is just vibrating and not making a grinding or scraping noise it is fine, if its vibrating too much for your like, try to rebalance your load.
Oct 03, 2012 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Front loader excessive vibration and walks.
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
heatman101
May 31, 2011 | LG WM2301HW Front Load Washer
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
Dec 09, 2010 | Washing Machines
My Bosh washing machine has excessive vibration according the the level i put on the top of the washer it is level, but still seems to walk accross the floor on the final spin cycle.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
Feb 05, 2010 | Washing Machines
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer LSQ9659pw4, very excessive vibration and walking
hello im proably the only one that will jump on this how old is this unit
Mar 29, 2008 | Washing Machines
Maytag MAH8700A Front Load Washer Logo
112 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
