My wash machine does not agitate or drain water out. makes a humming noise instead
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 01, 2010
Washer filles with water then buzzes
hi Timothy.
MOST PROBABLE REASONS FOR A BUZZING SOUND IN WASHING MACHINE:
  1. Blocked Drain Pump: An object has lodged itself inside of the drain pump. There can be items such as a small sock, a coin, a toothpick, or something small in your clothes pockets when you wash them. These items can fall out of the pockets and end up in the drain pump causing it to become blocked and make the buzzing noise you hear. Here is an audio recording of a blocked drain pump. Unfortunately, the only way to fix this problem is to take the washing machine apart and open up the pump and remove the object causing the buzz sound. To find directions to take your specific washing machine apart, do a Google search for Make and Model of your washer.
  2. Motor Coupling Broken: The motor coupling has broke and the motor turns but nothing happens. This will also cause a buzzing noise which can also be described as a vibrating noise. To fix this issue you will need to take the washer apart. Here is a video to show you what to look for if your washer motor coupler is broken. Once you know that the motor coupling is broken and needs replaced, we recommend ordering the part online. Simply do a search for "washing machine model motor coupler" and you will find the part needed for your specific washing machine.
  3. Washer Drive Block Loose or Worn: The washer drive block is not tight or has worn out. The part will need to be replaced to fix this problem. Here is an audio clip of a worn washer drive block to help you to diagnose that this is your actual issue. To further assist you with this issue, here is a video to show you how to replace a washer drive block.
  4. Worn Agitator Dogs: When these are worn, you will hear a clicking or crunching noise. These small plastic parts are used to turn the top of the agitator in one direction. This pushes the clothes down to the bottom part of the agitator to be washed. Here is what your washing machine will sound like when the agitator dog ears are worn. To replace these, order them online (about $5 bucks) and then install them in your washer. Here is a video to show you how to remove and replace washing machine agitator dogs.
  5. Washer Motor Burned Out: This may result in a buzzing noise depending on circumstances. The way to tell a bad motor is a distinct burning smell. This usually means your washing machine is old and the motor has died from old age. You may need to start thinking about buying a new washing machine. if that is not possible, you can buy a new washer motor for around $100 and install it yourself. Here is video showing how to remove a washing machine motor.
or try this.
Drain hose: If the washing machine is functioning correctly but makes a hummingsound while draining, there could be a problem with the drain hose. ... Then unplug thewashing machine and turn off the taps supplying water to it. Unscrew the fill hoses from the water valve.3 Nov 2014
Why Is My Washing Machine Humming? - Surewise.com
https://www.surewise.com/appliance.../8-reasons-why-your-washing-machine-is-hummi...
Based on your details, I would first check the drain pump to see if it's locked up due to a piece of clothing stuck inside the pump. You can remove the pump from the motor leaving the two hoses attached and then see if the motor will start. If it continues to just hum instead of starting, then it may be losing the start voltage. The motor needs start voltage and run voltage in order to start. The motor will just hum if it's not getting the start voltage.  The start voltage circuit is usually the red and yellow wires. Check the yellow and red wires at the motor, capacitor and at the timer for a loose connection. Make sure the red and yellow wires are pushed in all the way at the timer terminal quick disconnect plug. 120 volts should be present when measuring across the red and yellow wires. Check the white wire with the black stripe too at the timer and motor.
Washer filles with water then buzzes Google Search
Nov 24, 2017 | Washing Machines
Whirlpool washing machine wont drain or spin but will agitate
you have a bad lid switch. located under lid on left side of machine.
Dec 24, 2014 | Whirlpool Washing Machines
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
No washing action form the dishwasher
sounds like you have a broken wash pump or if there is a humming sound instead of water splash/spray noise ,something is jammed in pump impellors
Oct 05, 2009 | Dishwashers
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
My Maytag Performa washing machine filled up with water, and now just makes a humming and clicking noise. It will not agitate, spin, or drain.
sounds like your drive belt is lose.
Open the machine and check it
here is the link for your PARTS
includes also drawing
Jun 19, 2008 | Maytag Washing Machines
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
