Question about Refrigerators
I just bought a brand new replacement Whirlpool refrigerator ice and water filter. After installing it in my refrigerator, I ran the water through the line for about 15 minutes. I kept seeing small opaque particles in the water. It's a week later and the particles are still in our water.
    Genius:
  • 1,073 Answers
Replace the new filter
Posted on May 09, 2008
Whirlpool wrx735sdbm03 refrigerator makes 3 beeps when press the ice disp lever. It also makes 3 beeps if i press the water disp. happened after i replaced water filter. do you have any suggestions?
Did you install the water filter properly? If it is not installed properly it will not allow water to go through. Then no Ice or chilled water...
Check user manual and pull the filter and reinstall it.
Oct 24, 2017 | Whirlpool Refrigerators
When I changed my filter in my Whirlpool refrigerator, my refrigerator stopped making ice and dispensing water. How do I get it to start back making ice and dispensing water.
If you still have the old filter replace the new with the previous. If all works OK check new filter for blockage or manufacturing defect. Usually most units will work with no filter installed.
It is likely that you have not fully assembled the new filter in the location.
The filter can be removed and there should be no leak and the ice maker and water dispenser should work just like before except the water is not filtered. This feature is available for customers who have whole house filters.
Hope this helps?
Nov 22, 2016 | Whirlpool Refrigerators
Whirlpool ER2CHMXPL ice tastes bad
If I were you id replace the ice filter or get an ice mold and put water in it and stick it in the freezer
Jan 16, 2012 | Whirlpool Refrigerators
Whirlpool icemaker not working properly
Jun 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Water & ice dispenser problem
Ensure there is proper water pressure and volume to the unit....replace the water filter....all should be fine.
clarkco
Apr 29, 2009 | Refrigerators
Whirlpool ED22PW water not reaching ice maker or front dispenser
It doesn't matter if a whirlpool or any other brand is new or not, if you don't use an inlet water filter the water will taste like **** and sediment will deposit and cause catastrophic ice maker and water dispenser failure.
Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
Water Filter removal/installation
Bought the filter replacement and read the instructions. Turn off ice maker and replace filter. Remove by turning 1/4 turn to the right. pull out old filter. Remove cover, slide off, replace cover by sliding on the new filter. Push new filter in to the holding, hold so cover is horizontal, push in and turn back clockwise till the cover is horizontal to the floor.
Feb 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Dec 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
