Fan outside doesnt come on. ive cleaned the coils outside turned switch on and off. CHECKED THERMOSTATE WIRE. ALL CONNECTED.what else is there to do? when er had flood there was water in tube that drains into spout. I cleaned and rinse that out also.
  • 32 Answers
Did you check for power to the unit
Posted on Aug 31, 2010
I have a Coleman mach 3 ac unit. ive replaced everything except the compressor. the fan will come on but when i put it on ac it blows the fuse in the thermostat.
Fuse in the tstat?? First inspect the low voltage wire outside for imperfections, such as bare wires. Unhook the low voltage wires to condenser outside and cap with existing wire nuts. Then replace fuse and turn system on with cooling. If fuse still good then you have a short in the contactor coil in the condenser. Need new contactor. If fuse only blows when a call for cooling it's in the wire for low voltage or the contactor itself.
May 21, 2017 | Coleman Heating & Cooling
I have a 1974 harley I can't get it to fire. One port on the coil (bottom) has real slight fire. The top nothing? fxt lowrider
Test the primary side of the coil. Disconnect the small wires from both ends of the coil. Then, use a digital volt ohm meter to test the resistance of the coil. Put the meter's function switch in OHMS, R X 1 scale. Touch one meter probe to each one of the terminals on the ends of the coil. The meter should read between 5-6 ohms of resistance. If it does this, reconnect the white wire to the top terminal of the coil. Take a plain piece of wire and strip about an inch of insulation from each end. Connect one end of this wire to the bottom terminal of the coil. Put both spark plug wires in the coil with a spark plug in each wire. Make sure the plugs are grounded to the engine. Turn the ignition switch on and MOMENTARILY touch the wire you connected to the bottom terminal of the coil to the engine and then take it away from the engine. When you take the wire away from the engine ground, you should see a spark at both plugs. If not, the coil is bad. Have you cleaned and checked the gap on your points? Clean the points using a thin piece of stiff paper like a piece of index card with a bit of alcohol on it. Set the gap on the points to 0.020". Make sure the gray wire from the points is connected to the bottom terminal of the coil.
Good Luck
Steve
Aug 02, 2011 | Harley Davidson FXST Softail Standard...
We live in southwest Florida. Our HVAC system consists of a air conditioning system with heating coils when it is cool. Yesterday morning we tried the heat nothing come on. Later in the day I tried the air...
Hello. Sounds like you do have power. That spring loaded plastic switch is a 24v contactor. It pulls in when energized. If you push it in manually everything shoud run normal. Ck your 24v transformer. On one side (feed) you should have 115v or 220v depending on what kind of transformer is used likely (115v). Coming out of the transformer you should have 24v. If not you need a new transformer. You will need a mutimeter for this. If you know you have power where the wires are connected then you know how to use a mutimeter. Only way to know for sure outside of manually pushing in the contactor. Good luck. Be sure to kill the power before making repairs.
Jan 15, 2011 | Heating & Cooling
Son weed eating and hit wire outside now have no eletric to thermostate and wont come on wire is not broke into
The transformer may be shot. Place the fan switch on the thermostat from auto to run. The indoor fan should come on. If it doesn't then the transformer is probably bad. You can check for power on the transformer primary and then the secondary. If you have power on the primary and not on the secondary then it is no good either.
Sep 12, 2010 | Heating & Cooling
No fire in 91 v-max
check the continuity on the handlbar stop run switch.
the contacts my be carboned up in the switch.
Hope this helps
Apr 12, 2010 | 2000 Yamaha V-Max
Air condtioning unit outside fan will not move
Sounds like the motor start capacitor is gone south on you. you can get them at a motor rebuilder.
Jul 12, 2009 | Coleman Propane Forced Air Heater...
The outside fan motor (OFM) will not turn off.
it sounds like your fan connector is on the same side of the contactor where your high voltage enters you should have 3 wires 1 wire for each pole of the contactor and 1 wire off the capacitor does the compressor run all the time too? try turning the power switch off on your indoor air handler / gas furnace if the power goes off the fan goes off then it could be low voltage wiring
Jun 30, 2009 | Ruud UAMB Air Conditioner
The window unit is turned on, but doesnt seem to be very strong with blowing cold air . is there something that can be checked on the unit? something that can be replaced on the unit-like a filter? since...
first make sure the filter and coils are clean, then be sure you have it set for recirculate and not outside air allowance, and if ou wait til the room is very hot it will take a while to cool that room down to a comfort level. the fan and temperature control should both be at maximum if the room is very hot.
Jun 25, 2009 | Heating & Cooling
Fridge not cooling, freezer is ok.
Its usually a bulb of heat sensitive Gas then a long thin pipe that eventually connects to thermostate switch, bypass this switch to seee if that could be the faulty part. Good Luck , the Yeti
May 20, 2009 | Refrigerators
Problem with lights on install of a ceiling fan/light
ok...assuming the blue wire is the second wire coming from the light switch, it should be connected seperately to the black wire leading to the light(s). so the black lead of the switch should be connected to the power wire from the ceiling box and the blue wire should be connected to the black lead that goes to the lights. it sounds like you have the light leads connected to the main power, so the light switch would be bypassed, thus not operating correctly.
all white wires should be connected together unless one is being used as a return power from the wall switch, (which is often done).
hope this helps..........................jay
Mar 20, 2009 | Dryers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
