Question about Texas Instruments TI-30 Xa Solar Calculator
How would I be able to enter a varrible and get the actual solution for it on my TI-30X11S Calculator? Like for example, enter this into the calculator: 5(a - 12)= 8(3a 2) and get this: a = - 4? Am I able to do that? If so, how?
How do i put the 5(a-12)=8(3a2)and get this a=-4
Posted on Sep 27, 2010
How to use TI - 83 Plus To calculate Avrogados number?
Could you just enter 6.0221415 × 10^23?
This is within ± 0.0000010 of the actual number.
Good luck.
Paul
An Exact Value for Avogadro Number
Feb 16, 2016 | Texas Instruments TI-83 Plus Calculator
How to enter a binomial experiment problem on my ti-30x11s
See explanation on captured image below. Result in your case is 0.161
Mar 21, 2013 | Texas Instruments TI-30 XIIS Calculator
Here's the problem x - 5 = 10, how do I get the actual = sign to show up like this example?
It depends on the calculator. The Casios have two = signs. The main one tells the calculator to evaluate the expression entered. It is at the bottom of the face of the calculator.
There is a second key that helps you enter the = sign without executing the command. To type in that = sign, you press the ALPHA key followed by the CALC key. The = sign is entred. Usually that sign is used when you want to enter an equation to be solved.
What I said above to some Casio calculators. However your question is under the Texas Instruments Calculators heading, and I have no idea which TI calculator you have in mind,
Mar 11, 2013 | Texas Instruments Office Equipment &...
How to calculate cube root on simple calculator
That depends on how simple a calculator. I'll give some examples below for calculating the cube root of 8.
On a TI-86, press 3 2nd [MATH] F5 MORE F4 8 ENTER
If the calculator has a "^" or "y^x" key, raise 8 to the 1/3 power. Again, on the TI-86, press 8 ^ ( 1 / 3 ) ENTER
If the calculator has a logarithm key, take the logarithm, divide it by three, then take the antilogarithm. Again, on the TI-86, press 2nd [e^x] ( ln 8 / 3 ) ENTER
On a slide rule, place the hairline over the number on the K scale and read the cube root on the D scale.
Jan 10, 2013 | Texas Instruments TI-86 Calculator
How do i enter a decimal exponent in TI-30XA calculator. for example 10^-8.85
Use the 10^x function in the top row of the keyboard.
Press 2nd [10^x] +/- 8 . 8 5 =
The +/- key is just to the right of the decimal point key.
If you're entering integer exponents, you can use the EE key just above the 7 key. For example, to enter 10^8, you can press 1 EE 8
Apr 30, 2012 | Texas Instruments TI-30XA Calculator
I am using a TI-30 calculator and I am trying to calculate student loan payments. I need to know how to put a negative exponent into the calculator to process the formula. Example: (1+ .0075) to an...
Depending on your version of the TI-30, you will either find a button with a y to the exponent of x or a button that is the carot (^) sign. you would type (1.0075)^(-240), where ^ is the appropriate button (y^x or just ^).
Jul 18, 2011 | Computers & Internet
Can i do sigma notation on a ti-30xa calculator?
No. There are some keys on the TI-30XA that may make you think so, but they are statistical operations. For example, you can enter values using the Sigma+ key and the TI-30XA can give you the sum of the values entered, sum of the squares, mean value, standard deviation and so on.
You cannot do calculations like "Give me the sum of all integers from 1 to 100" with the TI-30XA, you'd need a far more sophisticated calculator.
Jan 06, 2011 | Texas Instruments TI-30XA Calculator
Hi how do i enter the cube root on my Texas Indstruments TI-30X11S
Use the xth-root function. It's the shifted function of the ^ key, above and left of the 7 key. For example, to calculate the cube root of 8, press 3 2nd [xth-root] 8 =
Nov 22, 2010 | Texas Instruments TI-30 XIIS Calculator
How do you enter exponents on a ti-30xa calculator?
Use the key marked "EE" (for Enter Exponent). For example, to enter 1.2 times 10 to the 17th, press 1 . 2 EE 1 7
Feb 07, 2010 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30 Xa Solar Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
