DTV conversion concerns
What is necessary to make my "HDTV capable" 2 year old set recieve true digital signals? Are the converter boxes available now capable of recieving and transferring the proper signal or are they just as the name implies 'Converters" which change the digital siganl to analog and supply it to the set? At the time of purchase I was assured that this particular unit would function with only the addition of a digital tuner box once the switch was completed. Did I get suckered?
Samsung DynaFlat HD HDTV 1080i
Model ~ TX3271HFX / XAA
I just purchased a Magnovox converter at Wal-Mart with the coupon I ordered from the government program. Our TV is about 2 years old too and not HD. It has worked great. The reception and color is truly the best we've had in years. We live in the country about 50 miles from all the local stations and were told we would need a new antenna, so far the only channel we have problems with is the PBS. Not sure if it is antenna related or their signal strength. We don't have the problem until the sun comes up good. It has been great to get the additional channels that some stations have added. Hope this helps.
Posted on May 09, 2008
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
2005 Conversion Van has TV What do I need to do to receive Signal
If the audiovox does not have digital capability you will need a converter. The converter "converts" the digital signal back to the old signal so that your tv will recognize and play it. Thanks for using fixya.
Mar 03, 2010 | Audiovox AVT1498 TV
DTV
Yes, you will need a HDTV converter box. Your set does not have a ATSC tuner that recieves HDTV signal. Your HD signal will be thru your Component Inputs on the rear jack panel along with audio IN.
Mar 04, 2009 | Hitachi 51F500 51" Rear Projection...
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Need help locating a box to make my TV receive true HDTV
Almost any electronics store should be able to help you out.
heres some helpful info from www.dtv2009.gov
go to the link for your $40 coupons
*note DTV and HDTV are two different things, you want the HDTV box
Certified converter boxes are available from both national and local retailers. Call ahead to confirm availability of coupon-eligible converter boxes on the day you plan to shop. National Retailers Converter boxes can be purchased at any of these national retailers currently participating in the program:
  • Best Buy
  • Circuit City
  • Kmart
  • RadioShack
  • Sears
  • Target
  • Wal-Mart
Locate participating national retailers in your area by completing the form below. Online and Telephone Retailers Converter boxes can also be purchased online or by telephone and can be shipped directly to your home. Online Retailers:
Telephone Retailers:
  • All American Direct at 1-800-249-1063
  • Best Buy DTV Hotline and Order Center at 1-877-BBY-DTV9 (1-877-229-3889)
  • Circuit City at 888-280-9382
  • DISH Network at 888-638-9912
  • Etronics at 1-800-323-7669
  • Fingerhut at 1-888-301-5606
  • iNet Access at 877-388-7010
  • Online Electronics Liquidation at 800-717-1635
  • RadioShack DTV Telephone Order Center at 1-877-RS-DTV-4U (1-877-773-8848)
  • Satellite Radio Superstore at 800-513-8554
  • Solid Signal at 1-866-3SIGNAL (1-866-374-4625)
Dec 19, 2008 | Hitachi 51F500 51" Rear Projection...
DTV and me
It only has the NTSC tuner. To recieve HD signals, you need to add a converter box.
Most cable and satellite companies by arrangement with the FCC still should work with the analog sets using their converter box without the need for a digital converter.
If all else fails, they do make for a nice computer monitor.
Nov 02, 2008 | Panasonic TC-20LA2D 20 in. LCD Television
Feb 2009
hi there
wouldn't a set top box work attatched to the unit, the spec says it will ?
beergut707
Oct 14, 2008 | LG Electronics LRM-519 Digital Media...
Greetings kathy76turne,
In February 2009 you will be unable to receive ANY analog television signals therefore the digital converter box will be a necessity to receive any over the air broadcasts.
I am unable to answer the question about the mini van's electrical capability, however you might find the following link handy to get more information.
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat120600050013&type=category
Thank you!
Dorothy
Go Ahead. Use Us.
Jun 09, 2008 | Mitsubishi HD-6000 DTV Receiver / Video...
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
