Question about Craftsman 12 Tilt Head Band Saw Owner Manual 113247210
I have a craftman 12" band saw when to turn it on it trips the breaker in breaker box I put new capacitor in motor but still the same ,does it in or out of saw
  • 32 Answers
It may be the start switch-that is one of the trouble shooting answers in the manual. (i.e motor not reaching speed)
Posted on Oct 24, 2010
  • bobweb1234 Jul 09, 2011
    That is the answer. I got one at a tage sale. I opened the electrical box on the motor and saw that the Switch PC Board for the starter switch had bent due to constant spring pressure. I inserted a spacer to press the board straight, and the saw started like new. Get a new switch, you will do better. Bob
    This is the answer. The PC Board for the switch warps with time. Inside the electrical box, you will see it. I inserted a spacer that pressed on the cover, and it started up fine. Get a new switch, a better solution
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
Table saw keeps tripping breaker
May have a brush in the motor that's hanging up or worn may try
replacing the brushes
Feb 07, 2014 | Saws
I have to push blade to start and after a little while breaker trips
The Start capacitor is bad. (CD60A) Made in China the min. order is 1000 peices, replace motor cost more than the saw, or get a 200 uf 250vac capacitor (Grainger) to replace the CD60A. It is larger so you have to mount it on top of the external cap on the motor. I think the CD60A is going to be a major problem on all these saws.
Feb 18, 2013 | Craftsman 10" Table Saw
Band saw motor won't start just hums
You will need to take the motor out and check the brushes on the back also check the bearings you may need to disassemble the motor to repair.
Apr 05, 2012 | Craftsman 12 Tilt Head Band Saw Owner...
Brand new saw trips 20 amp breaker every time I turn on the saw. It starts to turn and after about a second the breaker trips. Have tried different plugs on a different breaker. Still it will not start....
How long of an extension cord are you using? Is it at least a 14 gauge wire? It should be 12 gauge. If it 16 or a long 14 it will cause the problems that you mention.
If this is occuring when its plugged directly into the outlet then it is likely a problem with the saw. Before you take it back tho try another outlet on a a different circuit.
Jun 30, 2011 | Dewalt DW744XRS 10-inch Job Site Table Saw...
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
My 16 inch Band saw briefly bogged on a log resaw project. I think it may have tripped the fuse. What is the recommended fix for the fuse or switch?
No fuse for the motor has an overload protected circuit and resets itself usually within minutes. Your home circuit breaker or fuse in the electrical box needs to be checked.
Apr 06, 2010 | Jet JWBS-16B 708749B 16-inch Bandsaw
14" Delta Bandsaw keeps tripping the internal motor breaker.
The first thing that I would check is the wiring to the saw. My guess is that the wire to the saw or the cord is not heavy enough.
As saw like that can pull a lot of amps. Probably 15 or more when working hard. What happens is that when the amp draw goes up and the cord is too light, the voltage drops which increases the amps. and starts a vicious cycle...
The one thing that finally gives is the internal overload in your motor.
Try running heavier wire or a heavier extension cord if you are using one.
#12 wire or a 12 wire cord would be minimum, if running over say 50 feet then you should be looking at #10 wire.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 29, 2009 | Delta Saws
Can't turn planer on
I think that you burned out the start capacitor(s) on your motor.
This is a common problem if the motor is overloaded.
It is also possible that the thermal overload is defective.
Apr 09, 2009 | Powermatic 1791259/Model 2415 3HP 1Ph 230V...
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Craftsman 12 Tilt Head Band Saw Owner Manual 113247210 Logo
144 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
