My washer fills with water but does not begin the cycle. After filling with water the washer just stops. The dryer however is working fine. Can you assist with this please?
    President:
  • 3,773 Answers
Lid switch needs replacing
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 01, 2010
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Cold cycle does not work
hey thats crazy.anyway first things first.water passes through the fill valve.in the valve[ where the black fill hoses attach to your washer] are screens that stop minerals from going into the valve itsself and blocking up the valve internaly.i know its going tobe tough[trust me i've done 100s]but its how your complaint is solved 99 out of 100 times.you turn off the water remove the cold hose and clean the cold fill screen.also while the hose is off flush it into a bucket or the washer tub[wont hurt a thing]make sure you put the screen back into the valve.so next time valve wont get harmed.if the screen is clean and you have water at the cold facuet at the washer.you could have a bad valve.that would be a voltage check.we wont go there now.if you still need help you can email me thru fixya.hope this helps. God bless ,tom
Jan 08, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer won't start water fill/ the dryer works fine
I'm Neil, Glad to be of assistance for you!
Sounds like an Electronic problem.
You should call service.
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Aug 24, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
