Question about Hydro Slide NQD Hydro Speed Radio Control Boat
I just bought a nqd high wind rc boat. i charged the battery and put it in turned it on and it doesnt work
7000 double horse ep racing boat broke.
it is the force you aply to some thing and all that
Mar 03, 2014 | RC Gigantic Cyphelurus EP Racing Boat
Rc heli not responding
Make sure you have good batteries in the controller; if you are using it to charge the heli from they drain really quick. Good luck and have fun.
Feb 25, 2014 | Brookstone uControl Cloud Force RC...
My Double Horse 7000 RC boat will not run
myy was working then stoped. Battery was full. I disasemble it and found that the on/off switch stoped working because of the rust (water is getting inside). I manage to make a direct conection solding the black and red wire in this switch. Try it.
Jan 02, 2013 | Double Horse Radio Remote Control RC...
When i put it in the water and start going it works for a few feet in my control then it starts going in circles
the battery sometimes doesn't get charged very well. When the batter is low, it goes on auto pilot. When this happens to me, I'm usually turning the boat, which makes it go in circles until the batter dies. I learned that keeping the battery cool when charging will help it charge better to prevent this until fifteen or so minutes.
Aug 19, 2010 | Hobby Zone Hobbyzone Zig Zag Racer 3...
Cuts out
15 minutes is a reasonable time for a low cost RC boat. Is it cutting out because of low battery voltage?
Jun 02, 2010 | New Bright Radio Controled 18" 6Volt Sea...
How long do I charge my boat
All depends on the size of the battery and the charger youre using. Standard batteries are 7.2v on these boats pictured. You will have to check the mah which is on side of battery, if its 1800mah and youre charger charges at the rate 500mah you should charge it for 4.3hrs.
Mar 07, 2010 | Hydro Slide Radio Remote Control Hydro...
Exceed-Rc Problem
go to rcdiscuss.com, it's a good place for nitro rc car beginner
Apr 05, 2009 | Toys
Hydro Slide NQD Hydro Speed Radio Control Boat Logo
57 people viewed this question
Top Hydro Slide Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hydro Slide Toy Expert? Answer questions, earn points and help others
