Question about Vacuums
Electrical shock off metal tubing on tt5000 - Vacuums
  • yesdrib May 09, 2008
    cleaner is double insulated with the metal tubing isolated through the plastic handle. could be static, but quite a powerfull shock
Earth fault
Posted on May 09, 2008
Why does my dirt devil max upright vacuum shock me? When im making laps, vacuuming.
if it is during vacuumming carpets it may be static electricity generated by the plastic head over the carpet
if it happening n hard surfaces , take it in for a safety check as there may be a loose wire touching metal and causing you the shock
Jul 30, 2017 | Dirt Devil Vacuums
Static electric shocks
This occurs when the air is dry. The vacuum builds up a static charge when running. If you touch something metallic, you will get shocked. To dissipate the charge on your body, run your hand along a wall - it helps to reduce the shocks.
Apr 29, 2015 | Numatics Numatic Hetty 200a Hetty Hepa...
Why wont the brushes spin?
Most likely, the belt is broken. I'll bet the roller is covered with hair, thread, string. If brush roller is not routinely cleaned, string, hair becomes rapped around it and makes it more difficult for the belt to turn it. Eventually, the increase in friction and heat weakens the belt and the belt either breaks or stretches out. Try cleaning the rollers and replacing the belt.
Jul 29, 2014 | Miele Vacuums
Why wont the brushes spin on vacuum cleaner?
First, check to make sure that the roller is not hindered by a pulled string such from a carpet. Next check the BELT that drives the pulley. If the belt spins a little bit as if the electric motor is working and the belt is not broken, check the belt to see glazing. If it is glazed, it is not getting enough friction to spin the belt. Replace belt as needed.
Hi, I've got an Henry Hoover. I've got electric
TRY RUBBER GLOVE / IT WILL STOP ELECTRIC SHOCKS ,I AM A CLEANER AND IT WORKS FOR ME
Apr 09, 2013 | Vacuums
I own a Sanyo 35s 3.5 Rice cooker that has stopped cooking and heating. Power is going to the unit power light comes on. We have checked to make sure that the unit was turned off before unplugging as per...
if you have been washing or scratching the inner pot with something sharp or harsh like a metal spoon or hard sponge it could cause that and even electric shocks. try changing the pot
Jul 05, 2010 | Vacuums
Is it worth trying to fix the end of the power cord that goes in the wall outlet? One of the metal prongs broke.
You can buy just the end at the local hardware store. This is the best way to fix it. It is also the safest way to do it and not risk electric shock.
Jun 26, 2010 | Eureka Whirlwind 4383 Upright Vacuum
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My kenmore centtral vac runs but does not ****. HELP11
#1 i assume u checked the bag and filter if so equipped?
#2 verify the hose is not plugged
#3 verify hard plumbing not plugged by taking something metal (quarter) and crossing the 2 little metal nubs at inlet (don't worry it is low voltage u wll not get shocked) it should ****
#4 if hard line plugged you may need a second vacuum to reverse flow
are all outlets not creating suction f so detach vacuum from piping and verify that vacuum is not the problem
May 06, 2009 | Vacuums
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
