Question about Kenmore Elite HE5t Washer
Recently I have been getting an F20 error message. What does this mean?
  • Kenmore Master
  • 8,220 Answers
F20 No water detected entering machine
Could be a couple things . Clogged inlet screens on the water valve, flow meter gone bad. Pressure tube has sediment in it.
Recently I have been getting - ea359ae.jpg2c5596e.jpgRecently I have been getting - 425f67c.jpgttp://i.fixya.net/uploads/images/425f67c.jpg" alRecently I have been getting - a400199.jpgjpg" class="h_mi" />a400199.jpg
Posted on Aug 31, 2010
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: F20 Error Message
"F20" is a water inlet problem. This indicates you have insufficient water supply for the washer. Whirlpool is the manufacturer of your washer and they recommend that you unplug the washer and check the following:
1. Check water faucets to ensure they are completely turned on.
2. Check the inlet hose screens where they connect to the washer. The screens can clog with sediment over time and require cleaning. This can be a problem if you live in an area with well water and/or hard water.
3. Ensure the inlet hoses are in good shape and are not kinked.
If you check all the common sense items first and the problem still persists, you need to check the water inlet valve. To access, you will need to remove the top panel of the washer by removing the three screws that hold it in place. Once the screws are removed, the panel slides back, then off. The water inlet valve is located in the left-rear of the washer just prior to the dispenser. Double the electrical connectors to make sure they are not corroded and double check the hoses that run from the inlet valve to ensure they are not kinked. A resistance check of the water inlet solenoids (with the connectors removed) should read about 800 ohms. If the solenoid readings are abnormal, replace the valve.
Please post back if you have questions or require further assistance. I hope you find this information helpful.
Posted on Jun 12, 2008
jsrock516
  • 5911 Answers
SOURCE: my washer is showing error f20 what does it mean
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. The following link explains how to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
This is one of those error codes that can be tricky to troublehsoot due to the many potential causes of the problem. My adivce to you is to eliminate the easy common sense items first.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Posted on Feb 02, 2010
Fisher & paykel refrigerator RF195A
Hello!
Error F20 - it often means that the light bulb of the refrigerating chamber burned down. You need to replace it.
Here is also a link to the manual.
http://manualsbrain.com/en/manuals/1295058/?page=43
Hopefully, it will help you!
May 16, 2017 | Fisher Washing Machines
ERROR FF20 AND FF5
Hello Heather, this is JK. I understand that you received two error messages, F20 and F5. Typically, the F20 error indicates a communication failure between EOC and ESEC system and the F5 indicates that there is a runaway temperature. Based on the fact that you received both error messages, you may need to replace the EOC (Electronic Oven Control). Hope this helps!
Apr 19, 2014 | Frigidaire Kitchen Ranges
I am recieving a F20 error message on a brand new whirlpool washers each time i use it. Its a Duet Steam.
F20 means water is not entering the machine at a sufficent rate, check water supply is connected correctly, turned on and hoses are not blocked or kinked or pinched.
Jan 14, 2011 | Whirlpool Washing Machines
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the F20 message mean??????
Well the error F20 on display means (Water Inlet Problem, no water or insufficient water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
You can please check the following -
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Post comments for further help or information..........
Good Luck!!
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I'd like to know what the F20 message means on the Duet washer. I do not have a manual. Also, how do I get rid of it. Could it be an unbalanced load? Thank you for your assistance. Marilyn...
"F20" error code is a No Water Detected error. It is an indication that you either have no water coming into the washer, or very little water at all due to low pressure. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
May 17, 2010 | Whirlpool GHW9400 Duet Washer
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Jan 22, 2010 | Whirlpool GHW9300 Duet Washer
Finepix f20 to windows vista
Use a card reader to download your pictures to a folder you create on your desktop.
Oct 05, 2009 | Fuji FinePix F20 Digital Camera
Kenmore Elite HE5t Washer Logo
294 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
