Question about Maytag Dryers
How to open the top of a maytag performa dryer
  • 1,531 Answers
There are two clips about one inch in from either side on the front that need to be pushed in with a flat tip screwdriver this will release the lid
Posted on Aug 31, 2010
5 Suggested Answers
Jimster
  • 240 Answers
SOURCE: dryer won't start
Just a few things before the for sure thing. Make sure the dryer door is closed very good, and its plugged in (I hate doing that, but have a lot of calls with just that same thing). More than likely, it is the thermal fuse that has went bad. This fuse causes us more problems than any other item on the Performa. Unplug the unit, and take a putty knife and shove it into the top removing clips between the top and cabinet, around 1-2 inches in from the sides. Lift up and prop the lid against the wall, being sure it wont clunk you in the head (happens to me about once a week). In the left rear of the unit, you will see the element box. On (your facing side) the right hand side down about halfway, you will see two wires going to a small button shaped fuse. Remove the screw at the top of the element box (1/4") slide the fuse holder up and out (with wires still connected in case you drop it), and remove the fuse. The parts (LA-1053) will contain two fuses and a thermostat. Be sure to remove and replace the old thermostat when replacing the fuse. Follow instructions for which fuse to use, one is for gas, one is for electric. Reassemble is opposite disassembly. Let me know if you need further help. Jim
Posted on Nov 06, 2007
Washer_tech
  • 164 Answers
SOURCE: DRYER
you're not giving me much to work with. so for starters check the door switch
Posted on Dec 30, 2007
SOURCE: dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Posted on Mar 14, 2008
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Mar 06, 2010 | Maytag Dryers
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Oct 18, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
I have a maytag performa gas dryer. It is making
The skid pads are worn out or the rear rollers.
Aug 03, 2009 | Maytag Dryers
Kenmore Performa PYE2300: Drum won't turn anymore. Heat works and motor works-think it is a belt issue...silly question...how in the world do you get the back off of the dryer????
I beleive the dryer has to come off from front to get to belt open door and se if screws in there anywhere, where the top off cover should be able to pry open the top on each side and it lifts up
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer motor will not spin..motor sounds like it is sutck.
Get a putty knife, release the top by pressing the springclips between the front and top.
Then remove the front. The blower wheel may be the problem. They get loose.
Jan 04, 2009 | Maytag Performa PAV2200
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
How to get to heating element on dryer
the top will lift up put a putty knife in 2inches from the side and push in and release the tabs the element is in the back it looks like a spring
Nov 29, 2008 | Maytag Performa PAV2200
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
312 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
