Question about LG Heating & Cooling
Is there an easy answer for an LG air conditioner Model 58075050500 which was working fine earlier this summer to not come on. The outlet is fine, but the indicator on the plug is off.
    President:
  • 3,074 Answers
I believe there is a reset button on the plug itself, I may be wrong.
Posted on Sep 01, 2010
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
LG a/c not cooling
you may have freon leak, does the compressor turn on.?
Jun 02, 2013 | LG M5203L Air Conditioner
Bought this LG unit (LWHD7000HR) summer of 2010 and it worked fine - used very rarely. Did not use heat in winter either. Went to turn it on this summer and it does not cool. Fan operates but compressor...
Unplug the a/c and check the control panel of your a/c. Unscrew the control panel to expose the wires and terminal lugs.Check for lose wires or terminal lugs or defects from the compressor capacitor. If all are OK try adjusting the thermostat switch to make the contacts work. If the capacitor is damage replace it and replace any damage terminal lug. If the compressor still does not work, check the overload and the compressor resistance. If overload is open, replace it and check compressor amperage. If the compressor amperage is high, you have to replace the compressor, vacuum, and recharge freon.
Sep 02, 2011 | LG Heat cool Window Air Conditioner
My air conditioner worked fine last night, but when I tried to turn it on today in the 101 heat, it displayed E1 (blinking). I've unplugged it because it would not let me turn it off either.
If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced
Jul 22, 2011 | Samsung AW1203B Air Conditioner
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Jul 17, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
A.c. shuts off frequently
If you stored the unit upside down or sideways, the oil may have run out of the compressor. If the unit is reinstalled, it's important to let it sit in the correct position at least 24 hours before starting it back up.
Also check the condenser coil (the part of the unit that's sticks outside) and make sure it's clean. Likewise, check the filter and the evaporator coil (the coil on the inside) to make sure they are both clean.
Jul 07, 2010 | LG L8008R Air Conditioner
Power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
