Question about Asko W6021 Front Load Washer
Asko front load washing machine
The door won't close
  • Anonymous Jan 23, 2009
    Can't get the door to close and lock. The start/stop button just blinks at me. can't do laundry
  • Anonymous Mar 31, 2009
    The inside door on my Asko washing machine will not close because the interior mechanism needs to be replaced. What is this part called and where can I get it??
    President:
  • 1,294 Answers
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
Posted on May 10, 2008
  • prem mathew May 10, 2008
    Sorry, not on the door but on the mechanism on the machine.
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 14 Answers
SOURCE: Asko Front Load Washer major water overflow from powder dispenser
You may have the hose between the dispenser and bowl blocked
Posted on Feb 15, 2008
SOURCE: the door on my asko w6021 wont close
Hello
Well I'm sure you have power on machine if not check fuse located at rear of machine below lip.
Next step remove top cover a cheap saftey screw driver set
will do trick not standard drivers.Electrical drawing is located
inside,Photo copy,now locate a cheap multimeter for testing,
don't worry it's not rocket science.Look closely at cables notice all cables have numbers printed.If PWR lamp above switch is on proceed as follows.
Remove power from machine & test on the Ohms scale between
E111 & E113 if you have resistance great i can't remember value! Now put a bridge wire between E121 & E111with closed door should lock when machine is turned on ,if not you can test between V Volt scale ac & you should read about 30 Volts ac Between E113 &E111when you press door release button on front of machine.
Note the switch LB in drawing represents front door you can also
check across this on Ohms scale with no PWR.
Regards
Posted on May 06, 2008
  • 351 Answers
SOURCE: Asko W640 Front Loading Washing
may be carbons in motor and or board
Posted on Aug 27, 2008
  • 1294 Answers
SOURCE: asko front load washing machine
The door lock mechanism. You have to quote your model and number while ordering.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Mar 31, 2009
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Door won't open
has your machine got a filter that is exsessable if so you need to undo it and empty the water,( before the door will not open with water in the drum its a safety device if the filter is not on the front of your machine you will need to find it and clean
Dec 10, 2011 | Asko W6021 Front Load Washer
I'm trying to start the asko washer for the first time and I can't get the door to lock. the start button is blinking??
HI there, the door on my front loader was very hard to close, but the service people told me to close it really hard - slam it! and it has been fine ever since.
Jan 02, 2011 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Sites for spares:
RepairClinic.com
espares.co.uk
mcminone.com
Mar 31, 2009 | Asko W660
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
The door on my asko w6021 wont close
Hello
Regards
May 02, 2008 | Asko W6021 Front Load Washer
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Jun 11, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
204 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
