Question about Onkyo TXNR3007 91 Channels Receiver
No sound comes out when you turn the 3007 on you need to change channel, also if you leave it on stand-by when you turn it back on also no sound but this time changing channel does nothing you have to turn it off then back on again, then you have to change channel.
  • 2 more comments
  • nzdon1 Sep 01, 2010
    Will changing to factory settings change all my settings that I have inputted
  • nzdon1 Sep 02, 2010
    Both TV channels and also when you change sources, inputs are all HDMI
    I Have found the problem with the help of a Onkyo rep it was in hardware setup under HDMI audio tv out was set to on which was trying to send thr signal trought to the tv speakers,that been said the rep was surprised that I could get any sound. Thanks for your help any way
  • nzdon1 Sep 05, 2010
    This was the problem in the hardware setup Thank You
  • 979 Answers
Hello sir, hi, recheck for setup, and correct wiring, does your setup are all correct, you may need to check for the hardware setup.
Posted on Sep 03, 2010
  • Jerry Umali Sep 03, 2010
    any more problems?
  • 5,807 Answers
You may have an internal circuit problem,
But if you can DIY or have someone to help you.
I can be of help further troubleshooting inside the Unit.
Which requires , Voltage Measurement
and Initial Continuity Test.
You may ( or the other ) post the offset voltages on
the Output Amplifiers or have a further check on outputs
at the rear of the Unit.
You may need to check line out if sound or signals
can pass through , as to determine where the
fault actually comes. determining these would
save you a lot of time in electronics troubleshooting.
The choice will be yours.
Posted on Sep 02, 2010
  • Rommel Cana
    Rommel Cana Sep 03, 2010
    thanks for choosing Fixya for assistance.
    Or have the option of installing additional Audio cable your choice also.
  • 3,247 Answers
Please clarify what channels are you changing. By channels do you mean channels on the TV or the input channels in the Receiver , that is, you have to change the source inputs to make the sound come. What sound devices have you connected to it and through which inputs.
Posted on Sep 01, 2010
    Brigadier General:
  • 3,513 Answers
Hi
The problem is? sometimes switch relay switch sometimes not.
Try resetting it to factory setting. For Product Support Team Only:
1-800-229-1687 Hours: M-F 9am-8pm | Sat-Sun 10am-4pm ET?
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 31, 2010
How do I fix a black screen with sound working and LED light on.
Unplug the set and let it stand for two minutes. Plug it back in and see if it works. If that doesn't work contact Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 14, 2015 | Philips 42PFL3704D LCD TV
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Why is the power light blinking and the tv will not turn on?
It sound like the TV has gone into stand-by mode...
Try pressing one of the channel buttons, like the channel up or channel down button. That should bring it back out of stand-by mode.
Hope this helps :D
Any more questions, just ask!
Nov 23, 2010 | Toshiba 32A32 32" TV
Can not change channels by pushing channel numbers
Sounds like you don't have the tuner wired properly, IF you have a stand-alone tuner, then you need one wire to a continuous 12VDC for memory, the other 12VDC that's hot in accessory position, and then the ground. IF you hook the two 12volt wires together and they're only on when the car's on, then you will lose your memory of what channel it's on. Also, when you turn the radio off, turn it off with the BUTTON - not just by turning off the car. Give it a try using the radio's POWER BUTTON for on and off, NOT just the ignition, then it will remember the channel most of the time. Okay?
Jun 26, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Insignia Ns LCD-19 Turns on but no sound or picture
Insignia is Best Buy's store brand which is an LG tv. The power supply board needs to be tested to see if all the voltages it produces are present. If they are, then look at replacing the main board.
TV Parts Universal TV Stands DLP Chips ShopJimmy will have the parts you need.
Mar 20, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
No sound only pic
What do you mean exactly when you say 'there is no sound while changing the channels.' is there sound when you turn it to a channel and leave it there???
Mar 31, 2008 | Philips 32PF5320A 32 in. LCD Television
Onkyo TXNR3007 91 Channels Receiver Logo
556 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
