Question about Miele Optima G2470SCVi Built-in Dishwasher
Mildew and 'yuck' in the bottom inside dishwasher...how can i clean and disinfect?
  • Miele Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right… so me being the man I am tried in vain to clean the things…
Bought new spray arms online and installed them in minutes…now the thing works like new…
However I have also found that if the heating element goes bad then that also can mess things up bad…
So I would buy new spray arms, and also check out the heating element to make sure it is working…
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 01, 2010
Mitsubishi electric Mr Slim wall unit heat and air. strange smell coming out when air is on, we cleaned filters, but do not know where the heat exchange is or the the fan to clean them
Ductless split systems are know for creating a mildew looking "stuff" on the blower wheel. Try to open/move the louvers on the front of the indoor unit. By opening the "osculation blade"/louvers, you can see the blower wheel, normally blue in color. See if it has some mildew growing on it. If so, I found that a tooth brush and about 2 hrs labor does some good. I've found some aerosol spray, called mildew removal. Works great at covering up/controlling the smell. It's also possible that the unit is pulling air from the condensation drain line. These lines can for algae, and give us a sour yuck smell. To clean, use a wet vacuum, and clean from the outlet of the drain line. Hope this helps!
Aug 21, 2017 | Mitsubishi Heating & Cooling
How do I remove mold from inside the unit?
Only a mold expert (certified) can tell you its mold. I usually see a lot of mildew in the air handlers. Bleach will clean it but it will also stain and deteriorate any metal you get bleach on. I've found a coil cleaner at a refrigeration parts supply that has a disinfectant in it. EVAPORATOR NO RINSE WITH DISINFECTANT. I've only used it twice and haven't had the chance to go back to see if it helped keep it from growing. A U.V. light will help contain and control any growth. You may have an airflow issue allowing growth.
Jun 22, 2015 | Haier Heating & Cooling
When washer is discharging its water it comes out the air vent, the inside of washer is dirty. What can I do to fix the problem. Thank you ...
You need to take back of dish washer off unhook the drain hose and clean that hose good with soap and water or companies recommandations for cleaning hose and as for inside being dirty use a disinfectant clean the inside out and then after hoses are put back on and back is back on run dishwasher with no dishes and no soap for one cicle to rinse and test unit.
Oct 09, 2010 | Kenmore Dishwashers
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
Stinky water sitting in bottom of dishwasher
it's stale water growing bacteria, you can get a dishwasher cleaner at grocer that you dump in and run a cycle without dishes in there,....cleans and disinfects it,.....as always, read instructions, ask an employee at the store about it,....good luck, cracklin joe
Jan 07, 2010 | Dishwashers
My GE Eterna Series 3 Quiet power is not cleaning our dishes. Mostly the dishes on the top row has lots of stuff found in the glasses and mugs. YUCK!! I ran it for a minute and there is just water in...
I just took mine apart (bottom turntable, screen, etc.) and I was disgusted by the grime and gum that was clogging everything. I think it was keeping all the water a gritty white, which constantly left residue. I am currently running a load... hope that the "clean" dishwasher actually washes my dishes now!
Nov 18, 2009 | Maytag Dishwasher
Mold and mildew in door deal of LG front loader WM
Barb,
This is a problem with all front loaders. We have used those cleaning tablets in a regular hot cycle per the directions on the box. You can also try placing 1 cup of crystal dishwashing detergent in the tub and fill the soap dispenser with bleach and run a quick cycle full hot.
Aug 09, 2009 | LG WM-2277HW Front Load Washer
Mildew and long dishwasher cycle
Get some household bleach and run a short wash.
Aug 22, 2017 | Kenmore 24 in. 16533 Stainless Steel...
I have a GE PDW 8200 Dishwasher and there is standing water in the bottom of the tube. Why is there standing water after a complete cycle?
If it is older, the pump may not be draining the machine completely. The impellers, which is what acually moves the water could be clogged with yuck and could be cleaned if you can take the machine apart. If you call the repairman, he will likely replace the pump and motor.
Feb 24, 2009 | GE 24 in. Profile PDW7800 Built-in...
Black film on turn dials and inside door and bottom of bin
I have a similar KitchenAid model and we always ran it in energy saver mode. Over time, there was a significant buildup of mold/mildew in the unit that was not easily noticed.
Since that time, I took apart the inside of the unit and thoroughly cleaned it with bleach.
Now, we never use the energy saver mode and we use the sanitizer to make sure it gets hot enough so that it kills the mold/mildew on every cycle. The mold has not come back in over a year.
Dec 15, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Miele Optima G2470SCVi Built-in Dishwasher Logo
178 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
