Question about Garden
I have a "wild thing" Poulan 18" chainsaw which bogs down under a load. I would like to know which of the two star screws is the idle adjustment, and which is the high speed? I have an old craftsman 14" with a manual, and the manual simply and clearly explains how an amateur mechanic can correctly adjust the mixture, first at idle, then at cutting speed. The poulan owners manual only states to take it to a service center. Thanks, Fred
  • 252 Answers
The larger screw is for idle speed
and should be sett so that clutch does not engage the drum
usually idle is about 2000-2500 rpm and chain should not move
the two needles should be marked L and H
the lo base setting is usually 1- 1/4 turns out from lightly seated
the hi setting is usually the same but done while running @ top no load
sounds like you will have to richen the H setting 1/4 turn anti-clockwise the engine should putter or 4 stroke slightly at rev
caution do not set H too lean or damage may result
if you lean out the low too much the idle speed will increase and coversely if you richen it , it will lower the idle speed
you just need to find the spot where it idles good and accelerates cleanly with no hesitation when you gunn the throttle trigger
again dont set to lean
cheers
Posted on Sep 01, 2010
Testimonial: "01Sep2010 Thanks, pauly46. Fred"
    President:
  • 2,220 Answers
T is throttle (idle speed).
L is the idle and accelleration jet.
H is the high speed jet.
Posted on Aug 31, 2010
Testimonial: "01Sep2010 Thanks, dontbother10. Fred"
    Problem Solver:
I have a poulan pro 18" 42cc when I gun it it bogs down and stops before this it ran great my first chain saw. Does the carb need adjustment and how do I do that.
Thanks Dave
Posted on Oct 11, 2010
What do theT H L adjustment screws mean
These are the fuel adjustment screws, the L screw will adjust the fuel mixture from idle to half throttle, the H screw will adjust the fuel mixture from half throttle to maximum throttle, this will also control the maximum revs, the T screw is the tick over or idle adjust screw
Oct 12, 2011 | Poulan 18" Wild Thing Chainsaw
The idle adjustement screw had fallen out and was lodged under the carb. I put it back where it goes, but continue to have issues with idleing. Also, when I get it to a point where the engine will idle, I...
There is more than just an idle screw to adjust, you also have the high and low. Unfortunately, Poulan has limiter caps that require a special tool not available to consumers. To get the carb adjusted properly, you will have to take it to a local poulan dealer.
Aug 31, 2011 | Poulan 18" Wild Thing Chainsaw
Poulan 2375 will not idle
This sounds like a simple carb adjustment issue, however there is a special tool required to adjust the mixture, part no. 530035560, once you have the tool richen the L scerw on the carb by unscrewing it by 1/4 turn out, before making this adjustment, try just increasing the idle speed screw on the carb, this requires just a normal screw driver, do not increase it to the point ehere the chain is moving on idle.
Mar 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What causes the chainsaw to bog down and chain to stop when under light load
check chain is sharp oiled and tension is not too tight.if sawis old check engine compression is not low.
May 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild thing, 18", will not idle after throttle is released.
Need to change the fuel filter. It is inside of the fuel tank on the end of a small gas line. You need to carefully fish it out of the tank. Usually a piece of stiff wire with a hook bent on the end of it should do it or possibly a pickup tool. Then I'd recommend readjusting the carburetor. The default setting for the H and L carburetor jet is usually to turn them in all the way till they stop and back them out a turn and a half. You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a new wild thing poulan chainsaw that idles ok but bogs down when giving it gas ..it has good fuel
make sure your using high octane (no ethunal) and fresh oil mix no older than 6 mouth (oil mix) if it st-ell happens try to adjust the high side with it at full throttle un tell it smooths out. good luck
Oct 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the "T" adjustment on my Poulan Wild Thing?
The "T" position is just a mechanical stop for the Throttle.  It adjusts the idel speed by keeping the throttle from closing all of the way.  The "H" and "L" screws adjust carburator jets that feed the motor at High and Low speeds.
Apr 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 295 farm boss chainsaw
Try to adjust the air and gas intake pin. It is a screw type dial usually found sticking out the carburetor. You are tuning your carburetor, so you will have to test different adjustments until you get your desired running idle and power. I suggest you start with adjusting the air intake screws to decrease air supply going to the cumbustion chamber, It will probably make the chainsaw run when you give it a throttle.
Keep me updated
Mark
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
473 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
