Question about Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower
My zero turn husqy will turn but it won't idle, i changed spark plugs, fuel filter and bloowed the carburator and still won't idle
  • 472 Answers
Sounds like the govener is stuck
Posted on Sep 02, 2010
Testimonial: "i did check again it ran for a little while but it died again, everything else is working perfect. any more sugestions greatly appreciated."
Ybr 125 idling problems and stalling even after warmed up. Year 2009,any idea what the problem could be?
Battery charged enough? Alternator o.k.?
Bad idling should mean bad carburation -> is there a manual setting for the carburators? Look at the colour of the spark plug, inside the engine. Black=too rich engine. Mediumbrown=good. Light brown=too poor (in fuel) the mix. Oh, you should start with the idling screw, so the idling is a bit faster at first. Is the fuel flowing freely? fuel filters o.k.? Air filter too?
Aug 15, 2014 | Motorcycles
Won't start,has spark, has fuel
Are you sure the injectors are spraying if the pressure is zero ?
Have you checked the fuel pressure regulator ?
Are the spark plugs dry ?
Dec 12, 2012 | 1998 Cadillac DeVille
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
2005 honda element won't idle
COULD BE STOPPED UP FUEL FILTER.CHECK FUEL PRESSURE SHOULD BE 48 PSI. IF LOWER HONDA ADVISE TO REPLACE FUEL FILTER.YOU HAVE TO REMOVE FUEL PUMP THROUGH ACCESS PANEL FROM THE FLOOR.IF FUEL PRESSURE OKAY.REPLACE AIR FILTER.REPLACE SPARK PLUGS IF YOU HAVE OVER 110000 MILES ON THEM.IF SPARK PLUGS BEEN CHANGED ALREADY.IF ENGINE STILL WONT CRANK AND IDLE.CODE SCAN FOR A FAULTY IDLE AIR CONTROL VALVE.
May 12, 2011 | 2005 Honda Element
Runs rough at idle and wants to quit when you give it gas unless it is on full choke
This is usually an indication of fuel starvation. The jets in the carburator are probably clogged or (if you have a fuel filter) the fuel filter is clogged. In a well ventilated area and away from any sparks or flames, remove the carburator drain plug (usually at the bottom on the side of the bowl or on the bottom of the bowl). (Turn off the fuel flow to at the tank first). Try to catch the fuel as it exits in a small container. After you've drained the fuel from the carburator, examine the fuel and look for small particles. If they are present, you need to clean the jets which requires disassembly of the carburator. You'll need a manual and a rebuild kit for your particular bike to go beyond this step. However, if you're lucky, you can try turning on the fuel and flushing the carburator(s) out. If fuel only trickles out, then you've got a clogged fuel system. Could be the float valve or filter in this case. If fuel runs strongly, then if you still may have to clean the jets. Turn the fuel off, replace the plug(s), turn the fuel back on and give a few seconds for the bowls to refill and trying running the bike again. If it is fixed, then no further action is required except to keep your fuel cleaner! If not, you'll still have to clean the jets.
Apr 10, 2011 | Honda VT 1100 C Shadow Motorcycles
On my 89 Pathfinder,I changed my fuel filter an it turns over but still won't start. can i spay the carburator w/ carburator cleaner. will that help
If you smell fuel in your carburator I would check to see if you are getting spark to the plugs.
You can take starter fluid and spray into carburator and see if motor fires, if it does you may have a fuel pump problem.
Hope this helps you!
Mar 05, 2011 | 1989 Nissan Pathfinder
Echo shred n vac starts,idles, runs to about half power then bogs
Check the grommet that sits on top of tank where lines from go carb. Grommet may be rotten and crack. Try that. Have you ever replace the carb repair kit? The diaphram may be torn, defoam or have holes in them. Carb kit cost arount $10, but don't mess with the welch plug or screen in carb.
Feb 16, 2010 | ECHO, Inc. Shred n Vac
Hi there any help would be much help. Thanks 2005 klx It ran ok before I changed the oil and filter cleaned out the air filter and pulled air and idle crew for a blow out, after all that it won't start...
Is the spark plug too wet?
Probably theres too much fuel going into the combustion chamber, try to reduce the amount of fuel in the float chamber by first closing the petcock at the tank thn open up the fuel outlet screw at around the carburator float, just a little, close it up, remove the spark plug and clean it dry, refit it and try to start the engine..., adjust the idling screw a little inwards to increase the idling ..thn open up the petcock and observe the running of the engine ..if it starts to puut ..puut thn its for sure there is more fuel going in thn required ..you may hve to adjust the float.
Not bad to check if the carburator at the intake mounting is fitted right wth no air going through inbetween the carb and the intake mounting.
Hope this helps!
Dec 28, 2009 | 2005 kawasaki KLX 110
Stales when given gas
check the spark plugs and the fuel filter. also the intensity of the spark at the gap of the plugs. the spark should be bluish and you can hear a ticking sound. you can locate the fuel filter between the tank and the carburator, usually in the engine compartment.
Aug 29, 2009 | 1997 Saturn SL
Husqvarna 26 Hp 54" Deck Zero Turn Riding Mower Logo
132 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
