Always start high and work your way down...You want to maintain a 3ppm chlorine level.. Start by running a 12hr pump cycle with 10 hrs of chlorination... Check you chlorine level after 2 days and try to hit a target of 3ppm and after that, lower you cycle to maintain that level. For small pools, could be as low as 6 hrs pool pump, with 4 to 5 hrs chlorination??? I hope this helps you.. Good luck..
When the amount of available memory in flash memorybecomes low,
"FILE" flashes in the lower left corner ofthe display in all of the submodes
of the standard mode as well as in the dive mode. Thewatch
automatically switches to the flash memory statusdisplay of the system
monitor mode when the water sensor gets wet while thiswarning function
is activated. Please note that although it is possibleto use the watch for
diving in this state, log data may not be recorded inflash memory during
diving.
The file error warning function is also activated andadditional log data is not recorded if the
duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The
file error warning function may also be activated whenthe water temperature during diving is low.
It may not be possible to receive watchsettings by data communication while the file error warning
When the watch has switched to the file error warningdisplay, perform the garbage collection
procedure in the system monitor mode of the standardmode. Thedisplay returns to normal
following completion of garbagecollection.
Garbage collection begins when button (C) is pressedfor at least 2 seconds during the
flash memory status display.
• During the garbage collection operation, an alarmsounds and "G.C." is displayed on the
display. When garbage collection is completed,"Done" is displayed on the display.
• Garbage collection cannot be performed when"G.C." has changed to "NG" on the
battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed
on the disPress button (B) in the system monitor modeof the
standard mode to switch the watch to the Flash Memory
Status Display.
Formatting Flash Memory
Formatting of flash memory begins when button (B) is
pressed while pressing button (C) simultaneously forat
least 2 seconds.play at this time.
[email protected]
I've added a new field to the database to indicate which ones have been .... This one goes back to Win16 days. Finally updated for 32-bit! ... PrnInfo, 13-09-2006: Hook into the Windows Print Queue to find and ... SysInfo, 17-11-2009: Catch Windows device notifications, system settings updates, and power status. ... vb.mvps.org/samples/
If lights are flashing on the printer, I need to know how many flashes to know what to do. Unless the printer is on and with a ready light, you won't be able to print or collect status.
You must unplug the transformer to the system before installing the new battery so the system recognizes that the battery is in place. Once you have installed the battery it is safe to plug the transformer back in.
1. Remove the battery.
2. Remove the power chord from base station.
3. Leave it idle for 2 hrs.
4. Put back battery, connect the power chord.
Magic . it worked.
The printer is trying to collect data of it's status. Meaning its trying to get info on the ink andso on. Make sure your ink is installed and everything is hooked up correctly. Wait a few minutes before trying to use it. If it still says collecting printer status wait a few minutes.
