Question about Woods Hardware & Accessories
Can I set my timer to run for 15 minutes when I push the start button and then shut off
  • slpaulson Sep 01, 2010
    I have tried everything. How do I do it? ( So it runs for 15 minutes then shut off when I turn it on)
    How do I do it?
  • 10,319 Answers
These are made to run for one hour or more
Posted on Sep 02, 2010
  • 12,061 Answers
There is no reason why not, usually one can increment a timer in one min intervals, so simply set your timer for 15 "Intervals", or 15 Mins, and you should be OK.
Posted on Sep 01, 2010
Why is my pressure cooker not running the length of time set?
You probably need to push set again or something when it appears you should be done. I have a slow cooker and they work that way. It appears to be running but you still need to push one more button or the program will stop after 15 minutes.
Sep 21, 2014 | Cuisinart CPC-600 6 Quart Electric...
Tip
How to set timer for shutdown in windows os
step 1: click start menu button<br /> step 2: click on the 'run' button<br /> step 3: in the box that appears,type in the command ''shutdown -t 01"<br /> the computer will start shutting down in 01 seconds<br /> Note: By changing the value after the letter 't' in step three, u can set timer to shutdown for the specified value<br /> for eg: the command ''shutdown -t 15" will set the timer for shutdown to 15 seconds.
on Jul 20, 2011 | Computers & Internet
Tip
How to shutdown your computer very fastly in microsoft operating systems.
on Jun 19, 2011 | Computers & Internet
Just start 15 minutes and then stop
Pull the cover if necessary to see if the fan is spinning. If it's running 15 seconds, your door switches are probably ok, and the touchpad is working, main fuse ok. All that leaves is the circuit board and the magnetron.
Personally, I prefer microwaves with twist timers, not touch pads. A lot less to go wrong.
Nov 22, 2013 | Panasonic NN-S969 Microwave Oven
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
May 07, 2009 | GE DVL223EBWW Electric Dryer
How to set fm/1 stuz-l timer instructions
The timer works just like a lamp timer. First set it up on the correct time (white arrow on the inner circle). Next push the 15 minute increments down when you want the heater to run.
Apr 07, 2009 | Hardware & Accessories
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Hardware & Accessories Logo
74 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
jdthefixer
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
