Sound iv'e just set up my acer monitor but i cannot get any sound it was the last one so there was no instructions
  • Anonymous May 16, 2008
    Sudden no sound
  • Neutron_rock May 11, 2010
    What model or diagonal size...?
    Guru:
  • 859 Answers
You should have received a cable with a green plugh on either end. Plug one end in the color coded hole in the monitor and the other in the color coded hole in the back of the PC. If you've done all this, double click the speaker icon near the clock in the bottom right of the screen and see if the sliders are all up and there area no mute boxes ********** under those sliders.
You may also want to try onscreen menu for the monitor to see if there is an item for volume after your satisfied with the above settings and cable connections.
Sometimes a PC will have sound connectors along the backside of the case and also some towards the bottom that are horizontal to the floor. If there is some towards the bottom, that indicates you have an add in sound adapter card. when you have both switch the green plug from one to the other to check for sound. BTW, the best way to check for sound if everything is connected is to play a music cd. Don't forget that if you have a keyboard with extra keys one of those keys will control volume up or down as well a possibly mute too, so look them all over carefully.
If you uncertain about all this check with your local PC Guru for some over the shoulder coaching or have a local tech come by and check your system setup for that and any other problems they can inspect during an hour if that's how they charge. Most are happy to help within reason to earn a new good customer.
Posted on May 10, 2008
Installed new Acer P236H to a few years old Windows XP system. Graphics, pictures are squished and skewed, text appears fine. Have played with settings, OSD and Win Display. Never resolved problem, but...
What device-resolution combinations is your computer's video-card capable of? 1024 by 768 by 60 Hz? 1024 by 1024? Anything that matches that "native" resolution of the ACER?
You may need to upgrade your video-card, to support the "native" resolution of the ACER.
Jan 15, 2011 | Acer P235H LCD Monitor
GTA IV problems
try in game option a small resolution
Mar 07, 2010 | Acer AL1716 F Monitor
Monitor settings
Well yes you can reset your monitor, you need to completely switch off the monitor (means switch off your monitor from the main power not only using the on/off button) leave switch off your monitor for 24+ hours and check again, this procedure is known as hard reset...... Please post comments if further you have the same problem........
Good Luck!!
Thanks
Mar 02, 2010 | Acer AL1916W 19" LCD Monitor
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Im having trouble starting my acer laptop, iv tried pressin f2 and f8, and tried pressing safe mode options and others available, but it just goes onto the windows loading page and then to a black screen...
Try use last known settings that worked. If that doesn't work,reload your operating system, sounds like something might be corrupt.
Please rate my awnser. Thank you.
Jan 22, 2009 | Computers & Internet
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
In my acer AL1511 monitor speakers are available but sound is not coming
There are 02 possible reasons either video board of your crt monitor is dry soldered or video ic of monitor is defective : Last solution is to set EHT/FBT of your Monitor :
Darshan
Dec 26, 2008 | Computers & Internet
Monitor turns off
Since the green light is going out the monitor's power supply could be the culprit. That popping sound is not good. I would replace the monitor all together.
Jun 03, 2017 | Acer AL1715 (Black, Silver) 17" LCD...
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Acer AL1715s
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 20, 2007 | Acer AL1715s (Silver) 17" LCD Monitor
Computers & Internet Logo
505 people viewed this question
David Payne
David Payne
