Question about Sharp Wizard OZ-730
Sharp Wizard OZ-730 takes several attempts before it starts. Turns on and automatically off each time I want to use it. Can it be repaired? Helen
  • 2 more comments
  • Helen Greve Sep 02, 2010
    Hi Shiela65,
    Of course I know that it can be sent to Sharp for repair, however I beleived that Fixya
    would be able to advise me how to fix it.
    Helen
    Advice received was very generic. Of course I
    know that Wizard oz-730 can be sent back to Sharp for repair. However, I was led to believe Fixya could help me fix the problem based on experience with other callers. Someone must know have had a similar problem ie the unit turns on and off several times before it actually engages. Please help. Helen
  • Helen Greve Sep 03, 2010
    Thank you for trying to help.
    Re: Your response 1. The two AA batteries are checked and changed periodically before
    the unit goes dead.
    Hi Rockmeister,
    Response to your suggestions:
    1. The two AA batteries are changed peroidically before the unit goes dead.
    2. The power button has not been serviced. If that is the problem then sending
    to Sharp seems to be the only solution, right?
    Helen
  • 944 Answers
Hello Madam,
First we should find out what could be the problem and its solution.
1)First change AA batteries and check.Some batteries will go dead so we say the battery is stone dead.Your Sharp will try to get the charge but it will not able to.So wen you try lot of time it will get small amount charge that is left once it is on,The charge will be lost,So switches off.
2)The on/Off switch button is pressed a contact of rubber plate is made with the internal board so it get on/off.If water is poured on it ,Short circuit will cause this problem.If you have necessary screw drivers you can take apart and see water mater marks on the internal board.It will look like patch of water on the gold linings on the board.
3)The connector Jumber IC needs to soldered or replace if it is defective.Use multimeter and check you get any reading.If do not get solder it and check it else replace it.
If the Battery is new and if witches on and off then
Most the the charger IC will be defective.You have to replace this one.
Use continuity testing method on the board for diagnose of the problem.
Posted on Sep 04, 2010
    President:
  • 2,047 Answers
Yes your device can be repaired. But before the problem has to be determined.
First thing to be checked is the power pack is it still good enough to power the device because if the battery in completely dead the unit comes on for a bit and then blanks out.
has the power button been serviced? if the power button has not been serviced then it should be cheked because the power button might be making an inpartial contact which shuts down the unit aftr it is put on.
If these two seem not to be the problem then take the device to an expert for servicing and a more comprehensive diagnosis.
Hope this solution has been helpful?
Posted on Sep 03, 2010
  • Sharp Expert
  • 2,973 Answers
Helen,
Yes, it can be repaired. I feel that it has a faulty power on switch that is misbehaving. Please have it replaced from the Sharp service center.
Posted on Sep 01, 2010
How do i transfer a file from windows xp to a sharp wizard oz 730
You need the cable that came with the wizard. I think it is a serial cable. Then you need the software that came o a disk with the device. Does not matter, what port you use, serial or USB you always first need to install the software before you can connect it to the computer and work with it. Sometimes you still can fine the old software on the site of the producer of the device. (Sharp this time)
Jan 13, 2015 | Sharp Computers & Internet
Is there an online manual for this device?
Here is a link to the download of the manual online.
http://www.retrevo.com/support/Sharp-OZ-730PC-PDAs-and-Handhelds-manual/id/281bh528/t/2/
Hope it was helpful?
Feb 26, 2011 | Sharp Wizard OZ-730
Looking for software for OZ-730. Found that www.mywizard.com is no longer an accessible site.
CALL thewizardshop.net 803-736-4382 they have software and sharp organizers.The wizardshop can help you with ALL your Sharp Organizer needs.
Cords,software for Windows XP and 7. They have Sharp OZ-730,OZ-770 and YO-520. They also repair ALL Sharp organizers with a keyboard.
www.thewizardshop.net
803-736-4382
Nov 29, 2010 | Sharp Wizard OZ-730
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
I have an OZ-730 sharp wizard and it will not turn on, batteries are new and i tried the reset button. last time i used it the screen went black and then it turned off? help
Be sure the batteries are in correctly and are good, be sure the battery switch is back to the "normal position" - also it may have to be reset to work again - here is the instruction manual for doing that , page 7 chapter 1:
http://www.promsoft.com/dev/oz700sdk/oz7xx_manual.pdf
Sep 17, 2009 | Sharp Wizard OZ-730
Sharp OZ-730 (deceased
When you held the start button down and pressed the reset, did you get a message appear ? as per the manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000002412.pdf
Oct 11, 2017 | Sharp Wizard OZ-730
Sharp Wizard OZ-730
Hi, I has this same problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Dec 25, 2007 | Sharp Wizard OZ-730
Sharp Wizard OZ-730 docking module
Found it here -
http://underwooddistributing.com/Sharp/sharpyooz.html
but it's $49.95! I have to keep looking around the house.
Dec 21, 2007 | Sharp Wizard OZ-730
Sharp wizard oz-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
Oct 10, 2007 | Sharp Wizard OZ-730
Sharp Wizard OZ-730 Logo
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
