Question about Dryers
Maytag dryer wouldn't start. Model number is: mde9700ayw. Problem: Although dryer was set to warm/cold dryer dried the clothes on extreme high temperature. For the second load of clothes, dryer couldn't start. I replaced the control board where all control knobs are (I had spare which I had previously purchased from you) but the problem still exists-dryer wouldn't start. Is it possible to be the other mother board since when I try to turn on the dryer I just hear this clicking noises coming from relays/connectors as if the dryer wants to start running? Thank you!
  • Dryers Master
  • 3,051 Answers
HELLO THERE
I would have the board tested first and if it does indeed test out good than please try these things.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Aug 31, 2010
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
How to change maytag MDE9700AYW neptune dryer motor
Yes this was the problem. Dryer is happily drying clothes as we speak.
Apr 01, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer is not using heat. Each setting is like it's air drying. Why isn't it using warm air to dry?
have the element and stats tested with multimeter.. they should be in circuit.. bsc appliances 07779933829 postal service too.
Feb 27, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
The felt liner in the dryer came off and now it is making a thumping noise and we noticed some small oil spots on the cloths
I have a Maytag dryer, MDE9700AYW, and the felt liner at the front of the inside of the drum has torn away, at least most of it has. It take approximate 2 hours to dry a load of clothing. I cannot find the part number or the name of the part. I spoke with an appliance repair shop and they are unfamiliar with the felt liner. Can someone assist with obtaining a name, part #, and resolution?
Thanks,
Anthony
Jan 11, 2011 | Maytag Dryers
Does the maytag model number mde9700ayw have the
Yes it can be a gas dryer. If you have a electric dryer now though you can not convert to gas. If the dryer is set for propane the it can be converted to gas buy a licensed plumber or appliance repair man.
Good Luck
Apr 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
The dryer will not heat up to dry clothes
youve probably got a bad heating element, also make sure air is blowing out back of dryer to the outside of house if its plugged it will cause element to break good luck
Mar 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
