Question about Kenmore Elite 45986 Front Load Washer
F35 is flashing on my washer. It's locked but not completed the cycle, what should I do?
  • 1,531 Answers
You can use a wet dry shop vac and attach it to the end of the drain hose to remove all the water. Once the water is removed check the drain hose and pump for anything that may be restricting the water flow. once the water is removed the door will unlock
Posted on Aug 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: Keeps flashing F35, when unplugged and plugged
F35 Is an electrical fault in the Control Board.
Try setting the machine on off.
Then remove the plug from the wall for 5minutes. this will usually reset the system and get you going if it is only a glitch in the electrical system.
If this fails to remedy the problem then you have what appears to be a failed control board.
The only way to be sure is to have it diagnosed by a hands on tech.
Or risk your money by swapping it out your self.
The problem is that usually when my customers try this, they end up spending part money and then a service call on top of their failed attempt.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 16, 2009
SOURCE: He5t Kenmore ELITE front load washer flashing f35 code
I hate my machine. Just over a year old, F35 failure code. Wish I still had my reliable Maytag. And this failure is on a machine that replaced the FIRST one of these **** I bought. So I've had not one, but TWO units fail within 15 months of purchase! Anyone else have this miserable experience? What a total sham these machines are. Sears is less than supportive of their "flagship" product name.
Posted on Jun 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: Sears Kenmore HE3 Error Code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: my whirlpool washer flashes f35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
SOURCE: My Maytag 5000 front leader
We had the same exact problem. Service tech came out and diagnosed bad pressure switch, Part # W1015652. Swapped it for a $135 new one and it seems to work just fine now.
This would have been an easy fix for me to make had I known what to look for. Unplug and shut water, remove top cover, follow small diameter (1/4"?) black tube up from wash drum to where it plugs into the plastic pressure switch housing. Remove switch from its bracket, unplug wire harness and black tube, and replace.
Service tech said that this is due to using too much detergent, suds will creep up into the pressure tube from the wash drum and get into the small circuit board inside the pressure switch housing. He also recommended against using Kirkland Signature brand detergent even though it has the HE emblem on it. Best to use one of the major brands and only 1 to 1.5 tablespoons at most.
A google search for "Maytag 5000" reveals that this is a major problem because it is the 5th search result. "Maytag 5000 problems" search shows that this is the #1 problem with these washers.
Posted on Jan 03, 2011
Flashes Sud then F35 won't complete cycle
sounds like you have a "suds" lock. Too much detergent.
Oct 11, 2014 | Maytag Washing Machines
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
I start the machine the suds flashes then it goes away and the F35 flashes and nothing happends I tried to use the clean washer cycle and it still comes up F35 then when I try to push the cancel button the...
If this is a steam unit you have a bad analog pressure switch,has been a common issue in those units,Gives an F35 core and sometimes a SUD code.
Sep 20, 2009 | Washing Machines
F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Jun 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F35
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
My whirlpool washer flashes f35
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
43 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
