Question about Refrigerators
We are getting an accumulation of water in our top mount kenmore elite refrigerator. It seems to be dripping from the freezer. It is accuulating (and freezing) on the top shelf, and dripping and accumulating in the draweres and on the bottom of the refrigerator.
  • tpotente Sep 06, 2010
    We are also not able to get water flowing from the filtered water system on the front door--I have removed the filter which is full I am sure. Is this related to the water accumulation problem?
    I found there was considerable ice attached to a package trapped in the back blocking the vents. i cleaned it out and we'll see if that works!
  • 11,896 Answers
In the back bottom of the fridge there is a drain hose. It is supposed to drain water and drip into a drip tray that is heated and evaporates the water. If this drain hose is plugged, it will cause water build up to leak.
One other possible cause is the venting between fridge and freezer is building up with ice. You can remove the farthest rear panel of the freezer to gain access to the venting. You can try clearing it out so it defrosts properly and has proper air flow for cooling.
Posted on Aug 31, 2010
  • Nate Stansfield
    Nate Stansfield Sep 06, 2010
    It could very well be that the water line is frozen as well as the air vent between fridge and freezer. If possible, let it all that out for a minimum of a day, preferably two days. It should be good then, but it sucks to wait that long...I know
  • Nate Stansfield
    Sounds good!!!
Our kenmore top freezer is leaking (dripping water) inside the refrigerator section from around the dial area. Can fill up a small bowl in about 12 to 24 hours.
Most likely your defrost water drain is plugged. You will have to pull the panels off the freezer, to expose the evaporator. the defrost water drains by gravity thru a hole in the pan under the evaporator. Clear it of debris and or ice, check for any accumulated ice. reassemble. Remember to turn off power before attempting repair and be careful not to bend or puncture any refrigeration tubing
Jul 05, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Elite top mount refrigerator getting ice on top shelf and watr accumulating on bottom and in vegetable drawer. I cleaned the freezer and unblocked clogged ice but it still is a problem.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Kenmore 21.7 cu. ft. Top Mount...
Kenmore refrigerator 106.72206201 - accumulating ice and water
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Sep 11, 2009 | Kenmore Refrigerators
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
