Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag dishwasher won't start MDB5601AWW
Dishwasher won't start. It only turns on the green light and makes a little sound click. that is not thing else.
Thank you for help
There is a small round item in dishwasher on front bottom, if it is pulled up all the way the dishwasher will not allow water in.
Posted on May 09, 2008
Model MDB5601AWW leaking around the side plastic box on left wall inlet that has water hose. What needs done?
-Here sample solution.
-The plastic box or cap you're talking about is the " Breather Cap"
-Check the drain tube from the breather cap to the sink. It must be clean and no block.
-Make sure the breather cap stays in up right. (Straight Up)
-Check the breather cap's Cap . Any big chuck of food waste stuck inside or not. If so the clean it.
-Check the whole breather cap. Any crack...? If so the replace new one.
Good luck ,enjoy and wash every day
Mai
Oct 25, 2017 | Maytag MDB5601AWW Energy Star Built-in...
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Maytag dishwasher won't start but other buttons work
It's probably your Circuit Board (CB)! My dishwasher is on the second CB and it keeps blowing the dispenser transistor. This needs to be brought up to the MAYTAG goons to see if they will start recalling this crappy thing. My machine is barely a year old and will have it's third CB!
Jun 23, 2012 | Maytag MDB7749AWM Builtin Dishwasher
Own Maytag MDB5601AWW, serial 37004947LC - detergent dispener doesn't open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 ';
May 10, 2011 | Maytag Dishwashers
I have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Dec 01, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Maytag Quiet Series 300 Legacy Series Dishwasher
Mine was doing the same thing and I just pressed and held down the heated dry button until the light went off. Then I was able to start my machine as usual. Hope this works for you.
Mar 12, 2009 | Dishwashers
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Oct 05, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Dish washer won't start
make sure the water for the D/W is open
May 09, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher MDB5600awb
i need your serial num its important 17
Sep 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
528 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
