Question about Whirlpool GS475LEKS Gas Kitchen Range
Gs475LEMS 3 Gas oven or broiler won't start. Any ideas?
  • 1314 Answers
SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Posted on Jan 30, 2008
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
How do you get to it? On my stove there is no access panel
Posted on Mar 06, 2008
jsrock516
  • 5911 Answers
SOURCE: GE XL44 Oven/Broiler don't work
I'm assuming the top burners work, correct? Do you still have your Owner's manual? If so, go to the "Troubleshooting Tips" section and look under the "Surface Burners Light but Oven Does Not" tips. Follow the guidance provided. You may have a gas safety valve that is turned off.
If you do not have an owner's manual, you can go to geappliances.com. Click in the Search window and go to "Use and Care Manuals. Then, type in your model number in the adjacent window. You manual is available there in .pdf format. You can download a copy if you like. Make sure you have Adobe Acrobat reader in order to view it.
Now, if it's not as simple as a gas safety valve turned off, you may have two igniters that have gone bad at the same time. It is not common, but I have seen this happen before. Just because an igniter glows does not necessarily mean it is good. Click on the link below to learn about oven igniters.
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Double check the gas safety valve and reply back to me. Let me know if you need further assistance.
Posted on May 16, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
SOURCE: re: Jenn Air #svd48600b Gas Stove Top works...
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Posted on Sep 03, 2009
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
My gas oven turns on and starts to heat up but will not stay on. ANy ideas?
your oven gas pressure regulator valve needs to be replaced. it is a brass colored metal can attached to the oven broiler burner. you can get it at: searspartsdirect.com.
May 18, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Dec 24, 2007 | Amana ARGS7650SS Gas Kitchen Range
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven is slow to start
Dear Friend,
I had the same problem and the first step you should take is to replace the bake ignitor, you most likely to have a weak ignitor. If this doesn´t solve your problem, than your gas valve is failing. Despite the broiler is ok, the gas valve has independent channels for bake and broiler, so it´s possible for one to fail and the other is good. But i believe that changing nthe ignitor will solve it.
Zanes
Dec 03, 2006 | KitchenAid KGRT607 Gas Kitchen Range
Whirlpool GS475LEKS Gas Kitchen Range Logo
155 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
